oil pump cover #1098465
10/21/11 09:29 AM
10/21/11 09:29 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Looking to get an oil pump cover with the 2 fittings to make it simple to add a remote filter for my big block high volume pump.......is there any options other than milodon?
Re: oil pump cover [Re: mk_] #1098466
10/21/11 09:33 AM
10/21/11 09:33 AM
tboomer Offline
tboomer  Offline
Muscle Motors may have something...
Re: oil pump cover [Re: tboomer] #1098467
10/21/11 09:44 AM
10/21/11 09:44 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Anybody use the 440 source pump (melling hv) and cover
Re: oil pump cover [Re: earthmover] #1098468
10/21/11 10:38 AM
10/21/11 10:38 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I use the fitting in the block along with the fitting in the pump cover. But these are aftermarket blocks, which have the extra fitting.
If you want the two fitting deal you need to look at the milodon pump kits, which have a diff pump body and fitting along with the pump cover fitting.
Re: oil pump cover [Re: mk_] #1098469
10/21/11 12:17 PM
10/21/11 12:17 PM
AndyF Offline
AndyF  Offline
This cover eliminates the 90 degree bends by having the fittings going straight into the pump.
Re: oil pump cover [Re: AndyF] #1098470
10/21/11 12:22 PM
10/21/11 12:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Andy sure makes some cool parts
Re: oil pump cover [Re: mk_] #1098471
10/21/11 12:25 PM
10/21/11 12:25 PM
AndyF Offline
AndyF  Offline
The Milodon cover is probably the easiest to find. Indy also makes a two port cover.
I have a picture around here somewhere of an original Jensen cover. It was cast iron with NPT ports for an external filter.
Re: oil pump cover [Re: AndyF] #1098472
10/21/11 12:30 PM
10/21/11 12:30 PM
AndyF Offline
AndyF  Offline
440Source has a two port cover but they don't sell it by itself. Maybe if you call them they'll sell you just the cover.
http://store.440source.com/Billet-Alumin...tinfo/200-1102/
Re: oil pump cover [Re: mk_] #1098473
10/24/11 05:11 PM
10/24/11 05:11 PM
Out of the State of Confusion
blue_stocker Offline
I use the Milodon race pump and the Ecelectic Innovation's cover one of the MOPARTS members had his machinist friend design and make a few years back, nice piece and it works well too! It can be used with a std Melling-type pump or the Milodon race unit. I don't know if he's still making them but the last address for him was (Ted Hauser) Ecelectic Innovation, 4525 E. Industrial 4P, Simi Valley, Calif. 93063
Re: oil pump cover [Re: blue_stocker] #1098474
10/25/11 01:42 AM
10/25/11 01:42 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
he doesn't make them anymore, and has moved out of state.....
maybe he will make a batch someday,
