Re: oil pump cover
[Re: earthmover]
#1098468
10/21/11 10:38 AM
10/21/11 10:38 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I use the fitting in the block along with the fitting in the pump cover. But these are aftermarket blocks, which have the extra fitting. If you want the two fitting deal you need to look at the milodon pump kits, which have a diff pump body and fitting along with the pump cover fitting.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
