727 kickdown band, change in car? #1096539
10/17/11 08:20 PM
10/17/11 08:20 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I have heard this can be done but I am strugling, got the old one out ok but can't get the new one in
Any tips? I do have the flex band.
I have always pulled the trans but a Durango is kinda a pain, thought I would give this a try for once
Re: 727 kickdown band, change in car? [Re: HotRodDave] #1096540
10/17/11 08:30 PM
10/17/11 08:30 PM
Southern USA
TN_Michael Offline
TN_Michael  Offline
Southern USA
why dont you try to do the job right instead of hacking it? Is this a customers car?
Re: 727 kickdown band, change in car? [Re: TN_Michael] #1096541
10/17/11 08:33 PM
10/17/11 08:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The only kind I ever saw that you can change in the car is the two piece slip in bands. You have to cut the old band to get it out and then the two piece band slips around the drum and then you put the other end on and hook it up. I dont care for the slip in bands myself. I would take it out and do it right if it were mine. Ron
Re: 727 kickdown band, change in car? [Re: 383man] #1096542
10/17/11 08:53 PM
10/17/11 08:53 PM
Kalispell Mt.
Kalispell Mt.
My own personal car. Just figured that since I had heard so many times over the years it was possible I thought I would give it a try, if it won't go well no biggie, trans would have had to come out any how. Old band came out real easy but new one don't seem to want to go more than 1/2 way around. Just figured if it was easy as I had heard it would save me about 6 hours, trans was shifting fine just noticed during a routine service the band was near the end of the adjustment. VB come out in about 5 minutes with the pan off already, band strut in 2 minutes why not give it a try right. Not trying to "do it the wrong way", doing it the wrong way would be to pretend I didn't see nothin. Never heard of a 2 piece band, that sounds like the wrong way right there.
Why the moparts people getin their panties all in a wad lately over everything? If it won't work it won't work, why not just say "hey I tried it and it won't work"? Or if you never personaly tried it just sit back and listen?
Re: 727 kickdown band, change in car? [Re: HotRodDave] #1096543
10/17/11 09:15 PM
10/17/11 09:15 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
IF you toasted the band .. the drum is probably hurt tooo ..... the trans has got to come out ..
Re: 727 kickdown band, change in car? [Re: HotRodDave] #1096544
10/17/11 09:18 PM
10/17/11 09:18 PM
I totally agree and he's a newbie too
Re: 727 kickdown band, change in car? [Re: RapidRobert] #1096545
10/17/11 10:02 PM
10/17/11 10:02 PM
Southern USA
TN_Michael Offline
TN_Michael  Offline
Southern USA
Being a newbie has nothing to do with it. What matters is doing the job right and to not take short cuts. It is not a place to short cut. Knowledge & experience are king.
Re: 727 kickdown band, change in car? [Re: TN_Michael] #1096546
10/17/11 10:10 PM
10/17/11 10:10 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
it will go.you just got to keep wigglin and pushin on the drum and the band at the same time and all of a sudden it will slip right in like butter,but it can be frustrating.
Re: 727 kickdown band, change in car? [Re: TN_Michael] #1096547
10/17/11 10:19 PM
10/17/11 10:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you have pm.... no need to get the self rightous defenders of the written procedures up in arms.
Re: 727 kickdown band, change in car? [Re: dOrk !] #1096548
10/18/11 12:50 AM
10/18/11 12:50 AM
Kalispell Mt.
Kalispell Mt.
The old band was not "toasted" just worn till there was almost no adjustment left, no metal to metal contact, I am replaceing it as a precaution, drum looks great. I have lots of experiance with thease trannys, could build one blindfolded if it was on a bench, I have built tons of thease trannys, just never tried to stick a band in with the trans in the car. The opurtunity presented itself, I caught a problem before it was a problem, so I thought I would give it a try.
Re: 727 kickdown band, change in car? [Re: HotRodDave] #1096549
10/18/11 01:07 AM
10/18/11 01:07 AM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
this from the guy who cant do a simple google search for ATF ...
Re: 727 kickdown band, change in car? [Re: J_BODY] #1096550
10/18/11 01:58 AM
10/18/11 01:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you have pm.... no need to get the self righteous defenders of the written procedures up in arms.
If it's possible I'd like to know how , the fact that he got it out means there is enough room and it should go back in as easy as it came out. Personally I've never tried it and the times I have had a trans out and apart it never appeared like there was enough room to do it?
Re: 727 kickdown band, change in car? [Re: JohnRR] #1096551
10/18/11 09:46 AM
10/18/11 09:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've done it. maybe 3 or 4 times in the past 25 years.
And for the exact same reason as well - the 4wd Durango/Dakotas trucks that are one of the toughest trans to get out.
The way I look at it, if the trans is solid and theres no issues with the ft drum why pull the trans. It's less headache and saves the customer money.
That said, to get it in I think you have to hold your mouth right and it will go.
Re: 727 kickdown band, change in car? [Re: HotRodDave] #1096552
10/18/11 11:51 AM
10/18/11 11:51 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
haha
No, it wont work, and no I dont blame you at all for trying.
It's a complete pain in the ass to remove a 46re. I hate them which is why I converted to a 727.
You'll have to unbolt it and pull the front pump.
Re: 727 kickdown band, change in car? [Re: gtx6970] #1096553
10/18/11 11:53 AM
10/18/11 11:53 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I tried like crazy to do it and it wouldnt work for me.
I dont know what you're doing to accomplish it. the lugs on teh ends of the band made it impossible for me.
And yes they are an absolute nightmare to remove and a lot heavier than one would think. How do I know? I dropped one on myself doing it on a set of jackstands.
Re: 727 kickdown band, change in car? [Re: POS Dakota] #1096554
10/18/11 11:53 AM
10/18/11 11:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
haha
Why is it everytime I see you post your wrong?
As Bill stated above it can be done, not easy but it can be done.
Re: 727 kickdown band, change in car? [Re: 1_WILD_RT] #1096555
10/18/11 12:22 PM
10/18/11 12:22 PM
Kalispell Mt.
Kalispell Mt.
Complete change of plans, I just had a guy come in with another durango needing a 5.9 engine, I am pulling my engine and selling it to him, then re-building a spare 44RE I have in the corner and a 5.2 to match. I will have a complete rebuilt powertrain in my 240,000 Durango and hopefully get better than 14mpg. I will re-build the 46RE and sit it on the shelf till a needarises for it.
PS My tech who was off yesterday just got it to slide in in 5 minutes still gonna pull it all out.
Re: 727 kickdown band, change in car? [Re: 1_WILD_RT] #1096556
10/18/11 12:48 PM
10/18/11 12:48 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
haha
I dunno, maybe you're just a big tool with a chip on his shoulder who only sees what you want?
Yeah, I think so. In fact, I'm pretty sure I'm right on that one.
Re: 727 kickdown band, change in car? [Re: 68_CONV_300] #1096557
10/18/11 12:54 PM
10/18/11 12:54 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
THIS from a asshat newbie ...
EVERY topic on any internet site is "searchable".... and if we did just that ... there would be NO NEED for any type of forums.
Re: 727 kickdown band, change in car? [Re: POS Dakota] #1096558
10/18/11 01:14 PM
10/18/11 01:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wrong again ....
