Anyone use SEAFOAM? #1095778
10/16/11 07:07 PM
10/16/11 07:07 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I just tried a can of Seaform in my 69 roadrunner and 2003 Hemi Ram truck. I put a can in the oil and fuel tanks. So far i have not noticed anything much different though.
Now I was mentioning this to a buddy who uses it and he said i need to change the oil right after putting it in as it's just a cleaner. The can's instructions say nothing about not leaving it in untill the next change which for me would be next year.
Any opinions on this??
Stu
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095779
10/16/11 07:52 PM
10/16/11 07:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've used seafoam as a combustion chamber cleaner, IE pour it down the carb while the engine's running to clean out the carbon deposits. I've also used it in the fuel tank of my boat. I'm not a firm believer in putting anything special in the oil, because a well maintained engine with regular oil changes will stay very clean inside. My stock unopened 76 440 was super clean inside when I cracked it open for the first time.
The seafoam is a cleaner, however I don't think one small bottle of seafoam in the oil will hurt anything if run in there long-term.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095780
10/16/11 07:56 PM
10/16/11 07:56 PM
Kirkland, Washington
Pacnorthcuda Offline
I make my own Seafoam----50% Naptha and 50% Marvel Mystery oil. Seriously! Google it and you will find that its actually VERY close to whats in Seafoam.
Re: Anyone use SEAFOAM? [Re: Pacnorthcuda] #1095781
10/16/11 08:10 PM
10/16/11 08:10 PM
I kinda had a feeling it was pretty much Marvel Mystery oil just not as thick.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095782
10/16/11 08:40 PM
10/16/11 08:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I use it as a gasoline stabilizer. Had much better luck than with Sta-Bil.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095783
10/16/11 08:48 PM
10/16/11 08:48 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Stu
I've also used it as a combustion chamber cleaner. I got the idea from a tahoe z71 forum I go to sometimes. A lot of guys over there saying to change oil after a few hundred miles if you add it to the oil. I would just to be safe.
Walmart sells it by me so its real cheap too.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095784
10/16/11 10:41 PM
10/16/11 10:41 PM
I think it'd be good dribbled into the carb at a fast idle then drowning the eng with the last ounce of it then letting it sit overnight then taking it out for a blast (plugs may need cleaned to start it) to clean the combustion chamber . Into the gas itself I think it's snake oil and in the crankcase I wouldn't want to dilute my oil with it
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095785
10/16/11 11:22 PM
10/16/11 11:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What was wrong with your car?
What were you trying to fix with the seafoam?
Re: Anyone use SEAFOAM? [Re: autoxcuda] #1095786
10/16/11 11:34 PM
10/16/11 11:34 PM
North Central Florida
E
eightlitermopar Offline
E
It helps pass emissions, which is why I use it (Well, before I changed ignition and cleaned up the emissions)
Also down the carb to clean out the carbon deposits.
eight
Mopar or no car
Re: Anyone use SEAFOAM? [Re: eightlitermopar] #1095787
10/17/11 12:04 AM
10/17/11 12:04 AM
Andrewh Offline
Andrewh  Offline
The most frequently asked question about using Sea FoamŪ is as follows: “After using Sea FoamŪ in my oil, fuel, or through the vacuum line (to clean carbon from the combustion chamber) do I need to change my oil?” The short answer is: No you don’t have to change your oil after using Sea FoamŪ in any application.
http://www.seafoamsales.com/gasoline-engine-faqs.html
Re: Anyone use SEAFOAM? [Re: autoxcuda] #1095788
10/17/11 12:04 AM
10/17/11 12:04 AM
The engine had a slight lifter tick upon start up when sitting unstarted for more than a month so i was hoping the Seafoam would help. So far no more lifter noise but it has not been that long since it sat.
One thing i did notice the oil presssue comes up way faster than before i added it if that means anything other than the oil is more diluted.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095789
10/17/11 12:39 AM
10/17/11 12:39 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
it's a very strong solvent, smells like full strength alcohol. IMO it's most likely hurting lubrication and would be about like pouring a pint of lacquer thinner in your oil. I would change it......
Re: Anyone use SEAFOAM? [Re: GTXX] #1095790
10/17/11 12:46 AM
10/17/11 12:46 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Sorry Stu, but Seafoam has an interesting ring to it; like Snake Oil.
Mo' Farts
Moderated by "tbagger".
Re: Anyone use SEAFOAM? [Re: Grizzly] #1095791
10/17/11 02:23 AM
10/17/11 02:23 AM
hooziewhatsit Offline
I've used it for a few hundred miles before doing a regular oil change. Also used it in the gas tank as a fuel system cleaner.
It works awesome with small engines. Really cleans out deposits in the carbs and helps them run better, assuming there aren't other issues with the engine.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095792
10/17/11 08:35 AM
10/17/11 08:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I just dumped a can of it in my 74 gas tank last night right before I parked it at my MIL garage. It might be the last time I drive it this year? Hope not but I can't be sure with Cincy weather. I think last year I used stabil?
This past month I rebuilt my 25 year old eddie carb, it didn't even need it. My car sat with race gas in it for 16 years, so I know race gas is a good storage fuel.
But since I'm driving it a lot nowadays and race gas has gone up in price I rarely use race gas anymore except for my small engines.
BTW I get my prem gas from work and it has no ethanol in it. If I had to use ethanol gas I would store my car with race gas. No way I would store it with ethanol gas.
I have never put anything in my oil.
Re: Anyone use SEAFOAM? [Re: Challenger 1] #1095793
10/17/11 09:09 AM
10/17/11 09:09 AM
Seems there are varing ideas as to the legitimacy of Seaform and it's powers. Guess it's like most things that promise amazing claims..... individual results may vary!
Thanks for the feedback guys.
Re: Anyone use SEAFOAM? [Re: MidPenMopar] #1095794
10/17/11 10:07 AM
10/17/11 10:07 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ingesting it through the brake booster on my /6 Duster helped out very much. It actually stopped smoking (assumed to be a valve seal at the time, was sitting for 17 years or something).
I need to run some through the intake of my Wrangler and my Wife's Caliber. It does help clean carbon out.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Anyone use SEAFOAM? [Re: Pacnorthcuda] #1095795
10/17/11 10:57 AM
10/17/11 10:57 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Where can one find naptha?
Re: Anyone use SEAFOAM? [Re: Commando1] #1095796
10/17/11 11:07 AM
10/17/11 11:07 AM
NY usa
540challenger Offline
NY usa
You should find Naptha with the rest of the solvents in a Home Depot or Lowes.
Re: Anyone use SEAFOAM? [Re: RapidRobert] #1095797
10/17/11 11:20 AM
10/17/11 11:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Do the same thing with the same results with a soup can of diesel fuel. It doesn't have a catchy mane though like 'Seafoam'
