Anyone use SEAFOAM?
#1095778
10/16/11 07:07 PM
10/16/11 07:07 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I just tried a can of Seaform in my 69 roadrunner and 2003 Hemi Ram truck. I put a can in the oil and fuel tanks. So far i have not noticed anything much different though. Now I was mentioning this to a buddy who uses it and he said i need to change the oil right after putting it in as it's just a cleaner. The can's instructions say nothing about not leaving it in untill the next change which for me would be next year. Any opinions on this?? Thanks Stu
Re: Anyone use SEAFOAM?
[Re: Pacnorthcuda]
#1095781
10/16/11 08:10 PM
10/16/11 08:10 PM
MidPenMopar
I make my own Seafoam----50% Naptha and 50% Marvel Mystery oil. Seriously! Google it and you will find that its actually VERY close to whats in Seafoam.
I kinda had a feeling it was pretty much Marvel Mystery oil just not as thick.
[Re: MidPenMopar]
#1095782
10/16/11 08:40 PM
10/16/11 08:40 PM
Posts: 10,732 North Dakota
6PakBee
North Dakota
I use it as a gasoline stabilizer. Had much better luck than with Sta-Bil.
[Re: MidPenMopar]
#1095783
10/16/11 08:48 PM
10/16/11 08:48 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Thanks Stu
I've also used it as a combustion chamber cleaner. I got the idea from a tahoe z71 forum I go to sometimes. A lot of guys over there saying to change oil after a few hundred miles if you add it to the oil. I would just to be safe.
Walmart sells it by me so its real cheap too.
[Re: MidPenMopar]
#1095785
10/16/11 11:22 PM
10/16/11 11:22 PM
Posts: 27,470 So Cal
autoxcuda
So Cal
What was wrong with your car?
What were you trying to fix with the seafoam?
[Re: autoxcuda]
#1095786
10/16/11 11:34 PM
10/16/11 11:34 PM
Posts: 1,630 North Central Florida
eightlitermopar
It helps pass emissions, which is why I use it (Well, before I changed ignition and cleaned up the emissions)
Also down the carb to clean out the carbon deposits.
eight
Mopar or no car
[Re: autoxcuda]
#1095788
10/17/11 12:04 AM
10/17/11 12:04 AM
MidPenMopar
The engine had a slight lifter tick upon start up when sitting unstarted for more than a month so i was hoping the Seafoam would help. So far no more lifter noise but it has not been that long since it sat.
One thing i did notice the oil presssue comes up way faster than before i added it if that means anything other than the oil is more diluted.
[Re: Grizzly]
#1095791
10/17/11 02:23 AM
10/17/11 02:23 AM
Posts: 3,896 Oregon
hooziewhatsit
I've used it for a few hundred miles before doing a regular oil change. Also used it in the gas tank as a fuel system cleaner.
It works awesome with small engines. Really cleans out deposits in the carbs and helps them run better, assuming there aren't other issues with the engine.
[Re: MidPenMopar]
#1095792
10/17/11 08:35 AM
10/17/11 08:35 AM
Challenger 1
Cincinnati, Ohio
I just dumped a can of it in my 74 gas tank last night right before I parked it at my MIL garage. It might be the last time I drive it this year? Hope not but I can't be sure with Cincy weather. I think last year I used stabil? This past month I rebuilt my 25 year old eddie carb, it didn't even need it. My car sat with race gas in it for 16 years, so I know race gas is a good storage fuel. But since I'm driving it a lot nowadays and race gas has gone up in price I rarely use race gas anymore except for my small engines. BTW I get my prem gas from work and it has no ethanol in it. If I had to use ethanol gas I would store my car with race gas. No way I would store it with ethanol gas. I have never put anything in my oil.
[Re: Commando1]
#1095796
10/17/11 11:07 AM
10/17/11 11:07 AM
Posts: 2,826 NY usa
540challenger
NY usa
Where can one find naptha?
You should find Naptha with the rest of the solvents in a Home Depot or Lowes.
[Re: RapidRobert]
#1095797
10/17/11 11:20 AM
10/17/11 11:20 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I think it'd be good dribbled into the carb at a fast idle then drowning the eng with the last ounce of it then letting it sit overnight then taking it out for a blast (plugs may need cleaned to start it) to clean the combustion chamber . Into the gas itself I think it's snake oil and in the crankcase I wouldn't want to dilute my oil with it
Do the same thing with the same results with a soup can of diesel fuel. It doesn't have a catchy mane though like 'Seafoam'
