1970 CUDA DOME LIGHT INSTALLATION #1094361
10/14/11 04:09 PM
10/14/11 04:09 PM
PENNSYLVANIA, USA
RAPID1055 Offline OP
PENNSYLVANIA, USA
In process of replacing me dash pad. I figured this would be a good time to get the Dome light functioning.
1. Where does the Yellow & pink wires route/connect to.
2. What color coded wires should be connected to the left and right two terminal door switches.
Without help I will most likely end up taking apart the whole car.
Also, for the most part my repair manual is good, however it's the size of an aircraft manual and some information is marginal.
Would appreciate your help
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: RAPID1055] #1094362
10/14/11 04:16 PM
10/14/11 04:16 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: RAPID1055] #1094363
10/14/11 04:20 PM
10/14/11 04:20 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Dome lamp wiring runs down the drivers side C-pillar area and connect in the left body wiring with a 2 pin white connector.
The 2 door switches have a single yellow wire on each that connects to the main dash harness.
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: Snoopy] #1094364
10/14/11 04:31 PM
10/14/11 04:31 PM
PENNSYLVANIA, USA
PENNSYLVANIA, USA
Snoopy...appreciate the quick response and diagram.
Thanks Rapid1055
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: gtx6970] #1094365
10/14/11 04:35 PM
10/14/11 04:35 PM
PENNSYLVANIA, USA
PENNSYLVANIA, USA
gtx6970..appreciate the quick response and the process.
Thanks for all your help
Rapid1055
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: Snoopy] #1094366
10/14/11 05:04 PM
10/14/11 05:04 PM
PENNSYLVANIA, USA
PENNSYLVANIA, USA
Snoopy.
Can you tell where that drawing came from?
That is a well developed drawing and would appreciate it
if you could pass on the manual name or how I can get the info.
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: RAPID1055] #1094367
10/14/11 05:50 PM
10/14/11 05:50 PM
Snoopy Offline
Snoopy  Offline
It is a factory assembly line drawing. I managed to get it off another website before it was shut down. Faxon Auto Literature was suppose to offer complete manuals with these drawings, but so far they only offer ones for 1969. It looks like it was put on hold when Chrysler went into restructuring.
Faxon Assembly Line Manuals
Narrow search on left hand side of screen to 1969 and you can see what they have available. Great for the 69 people, bad for everyone else.
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: Snoopy] #1094368
10/14/11 06:51 PM
10/14/11 06:51 PM
PENNSYLVANIA, USA
PENNSYLVANIA, USA
Oh boy that's to bad. That would make things much easier.
Anyway thanks to you I can proceed with the install.
Please if you ever hear or find them would let me know Snoopy.
Many thanks
Would the 69 be of any value..any commonality between 69 and 70
Cuda
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: RAPID1055] #1094369
10/16/11 07:09 PM
10/16/11 07:09 PM
Snoopy Offline
Snoopy  Offline
Cuda
None, 69 is an A-Body and 70 is an E-Body.
Re: 1970 CUDA DOME LIGHT INSTALLATION [Re: Snoopy] #1094370
10/17/11 10:01 AM
10/17/11 10:01 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I am glad you saved that stuff. I made the mistake of just saving the links to information. Then a month later you click on the link and get the dreaded "This domain name is now available" screen. I now collect the web pages themselves.
Craig
