Issue at bottom og bore picture attached what to do ? #1086864
10/02/11 03:22 PM
10/02/11 03:22 PM
Gateway to the West.
hemi_harvester Offline OP
this is on the out side edge of the bottom of #4 bore on a 400 block. I can stick a paper clip into it to about where the line is at. I have taken the drain plug out of the side of the block and shined a bright flash into it ,I don't think it goes thru but can it cause problems in the future?
Is there a fix ? is this common ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Issue at bottom og bore picture attached what to do ? [Re: hemi_harvester] #1086865
10/02/11 04:00 PM
10/02/11 04:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd clean it up with a carbide cutter & get the block magged & pressure tested. stay safe, seeya.
Re: Issue at bottom og bore picture attached what to do ? [Re: rickraw] #1086866
10/02/11 06:41 PM
10/02/11 06:41 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am of the same thinking,,It is hard to tell from the fuzziness of the pic but is that a crack that started at a casting anomoly?
Re: Issue at bottom og bore picture attached what to do ? [Re: dartman366] #1086867
10/02/11 07:21 PM
10/02/11 07:21 PM
Pressure test and mag to be sure before investing time or money in it Way better to be safe than sorry Most everything is fixable, it ends up depending on how much and how hard it costs to fix it, it is probally nothing but to make sure
Re: Issue at bottom og bore picture attached what to do ? [Re: Cab_Burge] #1086868
10/02/11 07:26 PM
10/02/11 07:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I clearanced my first stroker years ago in the same area. The rod's got into the bore bottom's with the stock rod diameter and 4.15 stroke.. Back then there wasnt much choice for stroker cranks!
Re: Issue at bottom og bore picture attached what to do ? [Re: hemi_harvester] #1086869
10/03/11 12:00 AM
10/03/11 12:00 AM
NC
440Jim Offline
440Jim  Offline
NC
There is always the possibility that a crack will grow during use. So grinding the crack out smooth will help prevent that, assuming it does NOT go into the water jacket.
I don't know if that is the same location as the rod bolt clearance in a stroker, but here is one example for your evaluation.
