Issue at bottom og bore picture attached what to do ?
#1086864
10/02/11 03:22 PM
10/02/11 03:22 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
this is on the out side edge of the bottom of #4 bore on a 400 block. I can stick a paper clip into it to about where the line is at. I have taken the drain plug out of the side of the block and shined a bright flash into it ,I don't think it goes thru but can it cause problems in the future?
Is there a fix ? is this common ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Issue at bottom og bore picture attached what to do ?
[Re: rickraw]
#1086866
10/02/11 06:41 PM
10/02/11 06:41 PM
dartman366
Mt. Vernon, Ohio
i'd clean it up with a carbide cutter & get the block magged & pressure tested. stay safe, seeya.
I am of the same thinking,,It is hard to tell from the fuzziness of the pic but is that a crack that started at a casting anomoly?
[Re: dartman366]
#1086867
10/02/11 07:21 PM
10/02/11 07:21 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Pressure test and mag to be sure before investing time or money in it Way better to be safe than sorry Most everything is fixable, it ends up depending on how much and how hard it costs to fix it, it is probally nothing but to make sure
[Re: Cab_Burge]
#1086868
10/02/11 07:26 PM
10/02/11 07:26 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I clearanced my first stroker years ago in the same area. The rod's got into the bore bottom's with the stock rod diameter and 4.15 stroke.. Back then there wasnt much choice for stroker cranks!
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
