Beehive or dual valve springs? for big block
#1085472
09/29/11 11:08 PM
09/29/11 11:08 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
what is peoples experiance with beehive springs ? on a solid FT cam.under 600 lift. in a street strip car durability ? i see comp now lists some - same as big block chev. am i better off with duals,bite the bullet and swap out the inners for break in i do have source heads oh - i don't plan for over 6500RPM thoughts
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Beehive or dual valve springs? for big block
[Re: Locomotion]
#1085474
09/30/11 07:31 PM
09/30/11 07:31 PM
tex013
Sydney,Australia
thanks Locomotion, break in was what has me worried. obvious not many if any are using them in big blocks. Tex
[Re: AndyF]
#1085477
10/01/11 02:44 AM
10/01/11 02:44 AM
tex013
Sydney,Australia
thanks Andy, saw your write up on the 383 stroker.would you consider any break in issues possible if useing EDM solid lifters on either a comp or hughes cam with the beehive spring ?as opposed to the schubeck type or would the hughes cam,possibly faster ramp,and greater lift be a stretch ? comp XTQ286S 550/570 gross lift Hughes HTL5660BS3 579/587 gross lift
thanks again,
Tex
[Re: AndyF]
#1085479
10/01/11 09:39 PM
10/01/11 09:39 PM
tex013
Sydney,Australia
thanks mate, i had read but forgot about that article. i'll talk to comp next week
Tex
