what is peoples experiance with beehive springs ?
on a solid FT cam.under 600 lift.
in a street strip car
durability ?
i see comp now lists some - same as big block chev.
am i better off with duals,bite the bullet and swap out the inners for break in
i do have source heads
oh - i don't plan for over 6500RPM
thoughts
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
