Page 4 of 5 1 2 3 4 5
Re: Front Disk Brake Conversion not working as expected [Re: Rick_Ehrenberg] #1084451
10/05/11 04:54 PM
10/05/11 04:54 PM
Pittsburgh, PA
1970440RT Offline OP
Pittsburgh, PA
Well, I got the correct 1970 - 1974 calipers and hoses on the car and the spindles swapped side to side to get the calipers front mounted. This has solved the interference issues with the lower control arm. My lines and distribution block / valve won't be here for a while so I'll have to wait until this weekend when I get back from a business trip to test drive the new caliper set up.
Does anyone know where I can get the info to properly set up the booster pushrod?
Re: Front Disk Brake Conversion not working as expected [Re: autoxcuda] #1084452
10/06/11 02:30 PM
10/06/11 02:30 PM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
I looked and could not find the chart I saw. It showed the tall spindles toe change almost identical to the short one. I do agree camber change will change toe. Camber will change unless both upper and lower control arms are the same length. That's not going to happen.
Doug
Caster change in bump and rebound has a large effect on bump steer too. Looking at the side of the spindle in bump and rebound, the spindle rotates forward and back. That moves the lower tie rod end up and down and changes bump steer.
A lot of that comes from the side angle of the upper control that is made for anti dive. That's why Hotchkis relocated the upper control arms on thier B/E body arms to take some anti dive out (not fully remove) and reduce bump steer.
Steve’s right. We did change the location of the upper control arm pivot point for anti-dive and bump steer correction. Toe change during suspension compression and rebound makes a car less fun to drive hard and uncontrollable understeer when the toe change is severe enough.
We put this cool little video about the bump steer change with the Hotchkis TVS for the B and E bodies.
http://www.youtube.com/watch?v=VzxPWrdPlt0
Re: Front Disk Brake Conversion not working as expected [Re: AndyF] #1084453
10/07/11 11:09 AM
10/07/11 11:09 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Thanks for the heads up on the book, I have it pre-ordered. Since you have a 65 also, I'm looking forward to what you have written. Andy, you, Hotchkis, Firm Feel and Herr Ehrenberg kick butt!
Re: Front Disk Brake Conversion not working as expected [Re: CKessel] #1084454
10/07/11 12:29 PM
10/07/11 12:29 PM
AndyF Offline
AndyF  Offline
Thanks. I covered brakes inside and out in the book because the same issues keep coming up over and over on this board. Hopefully I answered everything well enough in the book to stop some of the confusion. It is a little easier in a book to cover the topic with pictures and text than it is on-line.
Re: Front Disk Brake Conversion not working as expected [Re: AndyF] #1084455
10/09/11 02:09 AM
10/09/11 02:09 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Not to change the subject, but since we are talking front end stuff, I was wondering when M.A. and Richard are going to update the article on the lower control arms that was run several issues ago. The suspense in waiting for the rest of the story is hard to take.
Carl Kessel
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084456
10/17/11 03:01 PM
10/17/11 03:01 PM
Pittsburgh, PA
Pittsburgh, PA
Sorry for the delay.
I am still having the front brake performance issue. The latest thing I did was install new s.s. brake lines throughout, including a new distribution block.
I rebled the master twice and the system three times, with vaccuum and pedal pressure. With the new master cylinder at a 7/8" bore, I can feel the longer stroke on the pedal but the brakes don't catch until near the bottom of the stroke. If I was new to the situation, I would guess that the system still has air in it somewhere but when I bleed, I get all fluid. Also, my bleeders are all located correctly at the top of the calipers.
At this point, I am so frustrated that I can't think straight. What the heck am I missing here? No matter how I adjust the Wilwood prop valve, the rears always lock up in a panic stop. I cant get the fronts to lock up at all.
This front brake performance issue has been the same since I first installed the conversion. I have changed the master cyl twice, lines, calipers twice, dist. block, and added a Wilwood prop valve.
The only thing I haven't touched are the rear brakes because they were done a year and a half ago.
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084457
10/17/11 04:06 PM
10/17/11 04:06 PM
I'd get (2) brass inverted flare male plugs from the "Edelman" parts bin at your parts house (they're cheap & you'll reuse em) and plug the M/C & if the mc is good and bled out with eng on the pedal will be rock hard and virtually no travel. There may be air downstream but that'd be a start and give you the satisfaction of some progress. I'd set the booster pushrod to 1/16" max or even a bit less. I'm assuming the rear drums are pretty tight. I'd say air or excessive p rod clearance. No opinion (yet) on why the fronts are not performing. I'd take care of the excessive pedal travel first.
Re: Front Disk Brake Conversion not working as expected [Re: RapidRobert] #1084458
10/17/11 04:15 PM
10/17/11 04:15 PM
Pittsburgh, PA
Pittsburgh, PA
Rapid, good idea. I will make sure master is good to go first.
The pushrod was adjusted to almost zero before I installed the master.
I also did not touch the booster but if that was bad, it should show itself as almost having manual brakes, right?
I could also block off the rear brakes completely and try operating with just the fronts to see exactly how well they perform.
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084459
10/17/11 04:25 PM
10/17/11 04:25 PM
(1) Yes I think pretty much so just like when you keep pressing them with the eng off. (2) Excellent idea to with a brass plug cap the rear brake port which'd be as you know the front port but I would cap both first. we gotta start somewhere to narrow this down
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084460
10/17/11 06:03 PM
10/17/11 06:03 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I'm experiencing a similar situation with not being able to adjust-out the rear lock up after installing a Wilwood prop valve. Which valve did you install? I'm using the 11179.
What size is your rear wheel cylinders and any thought about trying smaller ones?
Re: Front Disk Brake Conversion not working as expected [Re: cruzin] #1084461
10/17/11 10:11 PM
10/17/11 10:11 PM
Pittsburgh, PA
Pittsburgh, PA
just got in from the garage,
1. I isolated the master with plugs - rock hard pedal with engine running. Master cylinder and booster operating correctly.
2. blocked front brakes with a plug, had pressure to rears only. After bleeding rears, with engine on, good brake pedal. Rears OK
3. Reconnected front brake line to master, spongy pedal with engine running. Bled fronts, both calipers. Again spongy pedal with engine running. Rebled fronts, same spongy pedal.
All signs point to air in the front lines somewhere, can't find it. When bleeding calipers, get clear fuid - no bubbles. brand new brake hoses - rubber and stainless.
Did I possibly get a bad distribution block? can they trap air?
BTW: Cruzin, I got the prop valve from Mancini #WIL260-8419. I have the stock rear wheel cylinders.
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084462
10/17/11 11:27 PM
10/17/11 11:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just for fun, set the emergency brake then retest the foot brake. If the pedal firms up then your rear brake adjustment need tightening up.
It's also possible the calipers are mismounted. Some calipers do not take well to being swapped side for side to mount them on the other side of the spindle. Found that out on my 65 Cuda when I added discs.
Don't be the exception.
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084463
10/18/11 12:33 AM
10/18/11 12:33 AM
Progress . loosen the RF bleeder screw then tighten it finger tight just enough so it's shut off & have a helper jump on the pedal 4 times and with perfect timing you with your fingers open the bleeder as he's starting the 4th stomp & he holds it down till you close it. This agitates the fluid & can help get bubbles out. Repeat a number of times then do the LF the same. Ahead of time if the prop valve has an external pin valve on it pull it out & keep it out with a pair of vice grips. If this fails & I know you've checked all the front brake line fittings for tightness I'd actually take off the RF caliper and block the space in between the pads and bleed some more as you tilt it, repeat with LF. Sometimes the bleeder screw is at 12 0'clock but where this passage MEETS the bore is not at 12 0'clock so it's not the highest point and the highest point is where the air is going to rise to. OK; the M/C is bled out, the lines are tight, the prop valve usually does not hold air unless there's a high point so that only leaves the caliper. We're almost there EDIT if the pedal stomp does not help before I took a caliper(s) off I'd unscrew the front disc "out" line from the prop block & cap the block with a male plug same as you did the M/C & see if your now high and tight & if so rehook the line & continue on...
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084464
10/18/11 02:00 AM
10/18/11 02:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
More info on this DISTRIBUTION block ? Stock/original or aftermarket ?
Re: Front Disk Brake Conversion not working as expected [Re: JohnRR] #1084465
10/18/11 07:20 AM
10/18/11 07:20 AM
Pittsburgh, PA
Pittsburgh, PA
Rapid,
Good points, I'll try plugging the distribution block next to try to eliminate that from being a problem, then move to the calipers.
John- the distribution block I have now is a "supposed" good used. I bought a new one also but saw some threads about the new blocks having problems. I got the new block from Inline Tube, as well as the stainless lines.
Funny thing, my original block from my 4 wheel drum car is the same as the used one I got AND the new one Inline Tube sent, both purchased blocks were supposed to be for a 70-74 Challenger front disc, rear drum. Challenger 1's pics from this thread show a different distribution block on his Challengers from the factory. I didn't think too much about it because Ehrenberg's response in this thread indicated that the drum distribution block would work with the disc conversion.
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084466
10/18/11 08:31 AM
10/18/11 08:31 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084467
10/18/11 09:29 AM
10/18/11 09:29 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Rapid,
I have heard (and suffered this once at a repair shop), that a prop valve, especially when old, can move/stick durign bleeding.
Those valves never see the maintenance or replacement like the MC does, and they won't perform full travel on the valve unless one section of the brakes gets opened fully, which happens only during bleeding or brake system failure.
Yeah, they see some 'maintenance' and new fluid when brakes components are replaced, but they're still an old cast-iron part with rust inside.
Just a possibility to consider.
Re: Front Disk Brake Conversion not working as expected [Re: Fury Fan] #1084468
10/18/11 10:14 AM
10/18/11 10:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Rapid,
I don't know what material the valve is made of but the block itself is Brass not cast iron, I imagine if it were iron it would rust itself stuck in no time.
RT , the distribution block is just that , a distribution block , 67 to 69 cars used the same block disc or drum with a residual valve in the line to the rear, all that changed in 1970.
Re: Front Disk Brake Conversion not working as expected [Re: RapidRobert] #1084469
10/24/11 04:16 PM
10/24/11 04:16 PM
Pittsburgh, PA
Pittsburgh, PA
More Progress,
I swapped the distribution block and rebled the system and still have spongy pedal. While bleeding, I noticed that the drivers side rubber brake hose has more than noticeable movement when the brake pedal is pressed. No other rubber lines move when brakes are applied.
I blocked off the passenger side front brake line, leaving the driver side attached to the distribution block, still have spongy pedal.
I then plugged the driver side line at the distribution block and hooked the passenger side up and rebled. Voila... good pedal!
The problem is looks to be the driver side caliper and/or hose. I have a new caliper and hose on order and pick it up tomorrow morning. I hope this finally does the trick...
Re: Front Disk Brake Conversion not working as expected [Re: 1970440RT] #1084470
11/02/11 07:36 AM
11/02/11 07:36 AM
Pittsburgh, PA
Pittsburgh, PA
After changing the caliper and hose, the pedal still seemed spongy. I tried Rapid's advice on bleeding and even taking the calipers off the bracket to make sure the bleeder was at max 12 o'clock position and still the same ultimate result.
After all this work on the front lines, calipers, block and hoses- that all "had" to be good. I then looked to the master cylinder again. I still had the old (new from Ehrenberg) master with the large bore and figured what the heck. I had it installed in about ten minutes and bled. The pedal does not have much travel at all but with the prop valve almost completely dialing out the rear brakes, I can get the fronts to lock up first. The big bore master is making the pedal uncomfortably stiff but the system seems to finally work.
Any comments on why the small bore master didn't work? Bad master? pushrod/pedal ratios off? Should I try a different master?
Thanks to all who helped!
