rods too wide??? #1081759
09/24/11 09:37 PM
09/24/11 09:37 PM
louisiana
71440dart Offline OP
louisiana
i bought a 505 stroker from Hughes Engines, 4.25 stroke, and started final assembly today. the problem is i cannot put two rods on the same crank journal because they dont fit, they are chevy journals and measure like this- crank journal, 2.01, rods are 1.018 each. stock chevy rods measure .995 with the crank journal measuring 2.0. anyone ever run into this problem? i am going to call Hughes Engines Monday just wondering if anyone has ever had this problem. Thanks guys.
71 dodge dart race car,440/727 best so far: 11.23 @119 74 plymoth duster, 408SB/727
Re: rods too wide??? [Re: 71440dart] #1081760
09/24/11 09:40 PM
09/24/11 09:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Do they fit between the fillet but not down completely on the journal? If so look at the bearings & rods closely, one side is chamfered for clearance...
Re: rods too wide??? [Re: 1_WILD_RT] #1081761
09/24/11 09:42 PM
09/24/11 09:42 PM
louisiana
louisiana
forgot to put that but yes i checked it, i also tried to put two caps on without the rods, but to no avail.
Re: rods too wide??? [Re: 71440dart] #1081762
09/24/11 09:48 PM
09/24/11 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they cant even fit in the throw area(a pair of
rods) you can have the rods surface ground(I did
that 1 time on my small block) I had to take .013
off of the inside wall of each rod... or have the
crank cut wider(I JUST had this done on my 4" crank...
it was cut for chevy dia but he screwed up and didnt
cut the width... he did after I brought it back
Re: rods too wide??? [Re: MR_P_BODY] #1081763
09/24/11 09:55 PM
09/24/11 09:55 PM
louisiana
louisiana
if i do the rods i guess they have to be rebalanced? if i do the crank it would have to be nitrated and balanced again right? either way im not very happy with the parts that were supposed to be bolted in without any problems, hopefully it will all be worth it if i ever finish it. Thanks Mr. P body
Re: rods too wide??? [Re: 71440dart] #1081764
09/24/11 10:04 PM
09/24/11 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Call up Hughes and tell them to replace the crank...
on their dime
Re: rods too wide??? [Re: MR_P_BODY] #1081765
09/24/11 10:06 PM
09/24/11 10:06 PM
louisiana
louisiana
on their dime
i certainly expect them to do something, ive seen 505s with 4.25 cranks on there site for quite a while, apparently im the first person to try to put one together with this crank/rod combo.
Re: rods too wide??? [Re: 71440dart] #1081766
09/24/11 10:36 PM
09/24/11 10:36 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
went through all that when i finished up my 528 ci. earlier this year. i used the callies crankshaft and that measured the same as yours. i also ordered from them at the same time there compstar h-beam rods. there rods would have given me .030 side clearance as they came in at .990. although that is accepable by many, it's not want i wanted. i returned them. ( i just looked at there site and no longer see the 7.100 lenght any more.) suprisingly that 440 source reconizes this and makes there rods for chevy journal .994 width. that would have given me .022 side clearance. i chose to buy the eagle rods that had the L-19 bolts and they came in at 1.007. i did as Mr. pea Body had said and i surface ground the inner surfaces of the rods to .994 and ended up with .022 clearance. also in my case i mocked the engine up and checked everything prior to assembly, so every thing was ballanced after i was happy with all. good luck.
Re: rods too wide??? [Re: 71440dart] #1081767
09/24/11 10:37 PM
09/24/11 10:37 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You have Mopar width rods for a Chevy journal. Are these K1 rods or Eagles perhaps? There is a Chevy width rod, and a Mopar width rod, that both could be used on a Chevy journal, but the crank has to have the appropriate width.
RIP Monte Smith
Re: rods too wide??? [Re: CompWedgeEngines] #1081768
09/24/11 10:48 PM
09/24/11 10:48 PM
louisiana
louisiana
they are indeed K1 rods Competitionwedge.
i had hughes balance it before they shipped it.
Re: rods too wide??? [Re: CompWedgeEngines] #1081769
09/27/11 10:20 AM
09/27/11 10:20 AM
louisiana
louisiana
i spoke with Craig yesterday at hughes, he told me to box the rods up and they would send a return slip and have them picked up and correct the problem by cutting the sides. i asked about the balance and he told me it would not make a big difference. however this doesnt make sense to me. what do you guys think?
Re: rods too wide??? [Re: 71440dart] #1081770
09/27/11 10:35 AM
09/27/11 10:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
To me thats the wrong way to do it... if you go with
another set of chevy rods you would need to have those
cut down... I would have the crank widened... and yes
the balance would be off... I dont know how much
Re: rods too wide??? [Re: MR_P_BODY] #1081771
09/27/11 10:39 AM
09/27/11 10:39 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
on their dime
I doubt he wants to go down that road, He will basically be made out as the moron, and made to feel like a school boy playing with a 5 hp briggs.
Probbly just have to have the rods narrowed, and rebalance things.
Kasey
Re: rods too wide??? [Re: Moparnut426] #1081772
09/27/11 10:58 AM
09/27/11 10:58 AM
louisiana
louisiana
so say something happens and i need rods down the road, the crank journal is too wide for a standard width chevy rod, and not wide enough for a mopar width rod with chevy journal. so this is a total disaster. so really Mr. P body is correct or i need a new crank.
Re: rods too wide??? [Re: Moparnut426] #1081773
09/27/11 10:59 AM
09/27/11 10:59 AM
detroit area
moderncylinder Offline
detroit area
we always cut rods to get a final rod-rod clearance dimension,,
no,, absolutely no,,, no,, no,, you will not have to rebalance it,, cutting .020 off a big end will take about 1-2 grams off,, which will change the bobweight 2-4 grams..
do you rebalance your motor when you run 5-20 oil as compared to 20-50 oil,,, thats prob bout the same difference
Re: rods too wide??? [Re: moderncylinder] #1081774
09/27/11 11:06 AM
09/27/11 11:06 AM
louisiana
louisiana
no, but i dont pay 350 dollars to change my oil weight either. i asked because i didnt know.
off topic: does a quart of 20-50 weigh the same as 5-20?
Re: rods too wide??? [Re: 71440dart] #1081775
09/27/11 11:44 AM
09/27/11 11:44 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
He is trying to help you.
The oil weighs the same but because of the thicker viscosity there will be a larger volume of oil on the part.
Getting old just means you were smarter than some and luckier than others.
Re: rods too wide??? [Re: 71440dart] #1081776
09/27/11 11:58 AM
09/27/11 11:58 AM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Funny because they advertise no hassle - NO MACHINING stroker kits!!!!
Re: rods too wide??? [Re: dannysbee] #1081777
09/27/11 12:08 PM
09/27/11 12:08 PM
Until you get the oil hot
Re: rods too wide??? [Re: Cab_Burge] #1081778
09/27/11 12:34 PM
09/27/11 12:34 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
So at the start of the run it will be balanced and at the end of the run it will be slightly under balanced. May be a new speed secret.
