Used flat cam..... #1080771
09/23/11 09:53 AM
09/23/11 09:53 AM
Finally a HUSKER again
Moparnut426 Offline OP
Who on here accually will buy a used hydraulic flat tappet cam with suposedly matched lifters, and run it?
We have a guy comeing inn next week with an older GM, and he has a used cam from a "buddy" and he wants us to put it in. I told him we would but there is absolutely NO guarentee that its going to work without any issues.
He didnt understand that at all. I told him I would feel better if he bought a new set of lifters becaust you can not guarentee the lifters didnt get accidently switched around.
Hopefully he either buys a new set of lifters, or I scared him enough that he just gets everything new.
I have done it myself, but I pulled the cam out of a running engine, and swapped them out right there, no boxes duct taped together.
Kasey
Re: Used flat cam..... [Re: Moparnut426] #1080772
09/23/11 10:31 AM
09/23/11 10:31 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The thing that always scares me from using a used cam & lifters is that even if you do keep the lifters in the same order, the two blocks would have to have been machined exactly the same to ensure the same lifter-to-lobe wear pattern. I figure the odds of that are about slim and none, short of both blocks having had their lifter bores bushed by the same machinist using exactly the same equipment.
Re: Used flat cam..... [Re: Moparnut426] #1080773
09/23/11 10:38 AM
09/23/11 10:38 AM
an8sec70cuda Offline
Personally, I wouldn't build it at all unless he bought new lifters. Even if he agreed there was no warranty and if anything happened it was all on him...I still wouldn't put my name on it. No matter what happens, you built it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Used flat cam..... [Re: BradH] #1080774
09/23/11 10:48 AM
09/23/11 10:48 AM
Guitar Jones Online laugh2
I've heard this stated before and while I'll agree there can be a problem I don't think it's all that critical. I've had my solid flat tappet Hughes/Engle cam in two different stock blocks, a 68 340 and an 89 360 block with the same lifters. I've never had a problem with it even without any additives to the Mobil 1 oil I used.
Of course new lifters would be prefered but as long as he knows it's all on him, and you put it in writing with him signing, I'd do it. I take whatever I can get these days.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Used flat cam..... [Re: an8sec70cuda] #1080775
09/23/11 10:49 AM
09/23/11 10:49 AM
!!! true!!!
Well I seriously think he is gonna buy a new one. He must have talked to another guy and got the same answer I gave him.
Kasey
Re: Used flat cam..... [Re: Moparnut426] #1080776
09/23/11 01:14 PM
09/23/11 01:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I bought 2 solids froma old racer.The lifters were all in order.Ran them for about 6 years total.Never had a problem.At the shops I worked at there was never any guarantee when customers brought in their parts.We simply told them even if new and they didnt work that was tuff luck.No warranty or guarantees.If they didnt like it they could walk.You make $$ on parts not just labor.Im not fixing something that I didnt buy but just installed.Rocky
Chrysler Firepower
Re: Used flat cam..... [Re: therocks] #1080777
09/23/11 03:48 PM
09/23/11 03:48 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I would actually prefer a good used one to a new one, because someone else took the risk of the run-in, and if the used camkit is OK, then there should be no hardening fault or other issues with those parts. That is also my experience. I have had breakdowns with new stuff done correctly, so there must be quality problems as well, not only the wear pattern or lube issues. But there is always a risk... You are lucky if your client takes the risk, then you have your back free! My
Re: Used flat cam..... [Re: Oyvind Mopar] #1080778
09/23/11 07:44 PM
09/23/11 07:44 PM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
Im useing a used cam now in my 512 but I did get it from a friend so I knew it was good.One time in a small block chevy I put a used solid lift cam in but did not have lifter I had a set used big block lifters spent a little time on a surface plate with some wet/dry and lapped them in a figure 8 pattern and ran it for six years untill a connecting rod broke and shattered cam I agree with above post saves the worry of breaking in a new cam if you know its good.
Re: Used flat cam..... [Re: dcr] #1080779
09/23/11 08:11 PM
09/23/11 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
YEARS ago I used a hyd cam that a friend gave me and
all the lifters were just thrown in a box... worked great
(was in a chevy)
