Re: Used flat cam.....
[Re: Moparnut426]
#1080773
09/23/11 10:38 AM
09/23/11 10:38 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Personally, I wouldn't build it at all unless he bought new lifters. Even if he agreed there was no warranty and if anything happened it was all on him...I still wouldn't put my name on it. No matter what happens, you built it.
[Re: BradH]
#1080774
09/23/11 10:48 AM
09/23/11 10:48 AM
Guitar Jones
The thing that always scares me from using a used cam & lifters is that even if you do keep the lifters in the same order, the two blocks would have to have been machined exactly the same to ensure the same lifter-to-lobe wear pattern. I figure the odds of that are about slim and none, short of both blocks having had their lifter bores bushed by the same machinist using exactly the same equipment.
I've heard this stated before and while I'll agree there can be a problem I don't think it's all that critical. I've had my solid flat tappet Hughes/Engle cam in two different stock blocks, a 68 340 and an 89 360 block with the same lifters. I've never had a problem with it even without any additives to the Mobil 1 oil I used.
Of course new lifters would be prefered but as long as he knows it's all on him, and you put it in writing with him signing, I'd do it. I take whatever I can get these days.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Moparnut426]
#1080776
09/23/11 01:14 PM
09/23/11 01:14 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I bought 2 solids froma old racer.The lifters were all in order.Ran them for about 6 years total.Never had a problem.At the shops I worked at there was never any guarantee when customers brought in their parts.We simply told them even if new and they didnt work that was tuff luck.No warranty or guarantees.If they didnt like it they could walk.You make $$ on parts not just labor.Im not fixing something that I didnt buy but just installed.Rocky
Chrysler Firepower
[Re: dcr]
#1080779
09/23/11 08:11 PM
09/23/11 08:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
YEARS ago I used a hyd cam that a friend gave me and all the lifters were just thrown in a box... worked great (was in a chevy)
