Tranny dilemma~! #1080133
09/22/11 12:40 AM
09/22/11 12:40 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I am in the process of building a 4 speed tranny for my 68 Charger. I was able to find 3 extra 4 speeds, 2 A-body and 1 B-bodies. I now have 2 each 2.66, 1 each 2.45, and a 3.09 OD gear sets. It was suggested that I want the early A-body 3.09 gear set for my application.
I am running an extremely mild 572 StageV Hemi and 3.55 gears and I don't have tires yet . So from the experience of the Moparts tribe, what should I do? Should I try and trade a gearset? Or do I want to run what I now have? If run what I have, which set and why?
Thanks Tim
Re: Tranny dilemma~! [Re: astjp2] #1080134
09/22/11 02:52 AM
09/22/11 02:52 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I believe the 3.09 is a 6 cylinder gear and not that strong. plusw qa big drop to second.
You have enough torque to sdtsay with a 2.45 or 2.46 there's little difference but a 4.10 gear would be the tickedt
home of the
Sox and Martin Hemi Duster
Re: Tranny dilemma~! [Re: HEMIFRED] #1080135
09/22/11 04:59 AM
09/22/11 04:59 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I am planning on driving this on the street, that is why the 3.55 gears.
Re: Tranny dilemma~! [Re: astjp2] #1080136
09/22/11 06:33 AM
09/22/11 06:33 AM
Guitar Jones Offline
The 2.45 or 2.66 1st gear will be fine for you. Big cubes, lots of torque down low. The 3.09 was a 6 cylinder trans only to get that little thing moving. I don't think it was any weaker than the others per se but you won't need that steep of a 1st, plus as Fred said, there is a bigger spread between 1st and 2nd.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Tranny dilemma~! [Re: astjp2] #1080137
09/22/11 05:16 PM
09/22/11 05:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm a big fan of the 3.09 low gear for the street, I use 3.23 gears and get the same launch as 2.66 with 3.91's.
Sure there's a big drop between 1-2 but torque covers that.
Re: Tranny dilemma~! [Re: astjp2] #1080138
09/22/11 06:03 PM
09/22/11 06:03 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
3.55 gears? 8 3/4? I hope you don't plan on getting too crazy with the clutch and loud pedal.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Tranny dilemma~! [Re: I_bleed_MOPAR] #1080139
09/22/11 07:01 PM
09/22/11 07:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tim
He's using a 23 spline , he'll probably blow that up before the rear
Re: Tranny dilemma~! [Re: I_bleed_MOPAR] #1080140
09/23/11 12:35 AM
09/23/11 12:35 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Nope Dana 60 with Dana 70 gears installed.....
Tim
Re: Tranny dilemma~! [Re: JohnRR] #1080141
09/23/11 12:37 AM
09/23/11 12:37 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Hopefully a passon 5 speed will happen eventually!
Tim
Re: Tranny dilemma~! [Re: astjp2] #1080142
09/23/11 09:04 PM
09/23/11 09:04 PM
Buford, GA
Buford, GA
That's good to hear. Hope your trans lives until you can upgrade it.
Tim
'71 Charger 383/727
Re: Tranny dilemma~! [Re: I_bleed_MOPAR] #1080143
09/24/11 12:20 AM
09/24/11 12:20 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I am hoping that I can find one that I can afford, still building the motor right now!
Re: Tranny dilemma~! [Re: astjp2] #1080144
09/25/11 01:00 AM
09/25/11 01:00 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Can you convert a 307 bearing case to a 308 bearing? TIm
Re: Tranny dilemma~! [Re: astjp2] #1080145
09/25/11 04:29 PM
09/25/11 04:29 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Bump
Re: Tranny dilemma~! [Re: astjp2] #1080146
09/25/11 04:36 PM
09/25/11 04:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Requires machining and maybe some welding because the 308 bore will hit the bolt holes .
Why do you want to switch to the larger bearing ?
Re: Tranny dilemma~! [Re: astjp2] #1080147
09/25/11 04:37 PM
09/25/11 04:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tim
Never heard of that combination ...
Re: Tranny dilemma~! [Re: JohnRR] #1080148
09/25/11 06:43 PM
09/25/11 06:43 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
There is a link to it, search for Jana 76
https://board.moparts.org/ubbthreads/show...page=0&vc=1
Re: Tranny dilemma~! [Re: Guitar Jones] #1080149
09/25/11 07:04 PM
09/25/11 07:04 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The 3.09 1st gear was also used for some of the 318 cars..
Just my $0.02...
