Tranny dilemma~!
#1080133
09/22/11 12:40 AM
09/22/11 12:40 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Ok, I am in the process of building a 4 speed tranny for my 68 Charger. I was able to find 3 extra 4 speeds, 2 A-body and 1 B-bodies. I now have 2 each 2.66, 1 each 2.45, and a 3.09 OD gear sets. It was suggested that I want the early A-body 3.09 gear set for my application. I am running an extremely mild 572 StageV Hemi and 3.55 gears and I don't have tires yet . So from the experience of the Moparts tribe, what should I do? Should I try and trade a gearset? Or do I want to run what I now have? If run what I have, which set and why? Thanks Tim
Re: Tranny dilemma~!
[Re: astjp2]
#1080134
09/22/11 02:52 AM
09/22/11 02:52 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I believe the 3.09 is a 6 cylinder gear and not that strong. plusw qa big drop to second. You have enough torque to sdtsay with a 2.45 or 2.46 there's little difference but a 4.10 gear would be the tickedt
home of the Sox and Martin Hemi Duster
[Re: astjp2]
#1080136
09/22/11 06:33 AM
09/22/11 06:33 AM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
The 2.45 or 2.66 1st gear will be fine for you. Big cubes, lots of torque down low. The 3.09 was a 6 cylinder trans only to get that little thing moving. I don't think it was any weaker than the others per se but you won't need that steep of a 1st, plus as Fred said, there is a bigger spread between 1st and 2nd.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: astjp2]
#1080137
09/22/11 05:16 PM
09/22/11 05:16 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm a big fan of the 3.09 low gear for the street, I use 3.23 gears and get the same launch as 2.66 with 3.91's.
Sure there's a big drop between 1-2 but torque covers that.
[Re: astjp2]
#1080138
09/22/11 06:03 PM
09/22/11 06:03 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
3.55 gears? 8 3/4? I hope you don't plan on getting too crazy with the clutch and loud pedal. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1080139
09/22/11 07:01 PM
09/22/11 07:01 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Tim
He's using a 23 spline , he'll probably blow that up before the rear
[Re: astjp2]
#1080146
09/25/11 04:36 PM
09/25/11 04:36 PM
JohnRR
U.S.S.A.
Can you convert a 307 bearing case to a 308 bearing? TIm
Requires machining and maybe some welding because the 308 bore will hit the bolt holes .
Why do you want to switch to the larger bearing ?
[Re: astjp2]
#1080147
09/25/11 04:37 PM
09/25/11 04:37 PM
JohnRR
U.S.S.A.
Nope Dana 60 with Dana 70 gears installed.....
Tim
Never heard of that combination ...
[Re: Guitar Jones]
#1080149
09/25/11 07:04 PM
09/25/11 07:04 PM
Posts: 5,435 So Cal
Sinitro
So Cal
The 3.09 1st gear was also used for some of the 318 cars..
Just my $0.02...
