Tranny dilemma~!
#1080133
09/22/11 12:40 AM
09/22/11 12:40 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Ok, I am in the process of building a 4 speed tranny for my 68 Charger. I was able to find 3 extra 4 speeds, 2 A-body and 1 B-bodies. I now have 2 each 2.66, 1 each 2.45, and a 3.09 OD gear sets. It was suggested that I want the early A-body 3.09 gear set for my application. I am running an extremely mild 572 StageV Hemi and 3.55 gears and I don't have tires yet . So from the experience of the Moparts tribe, what should I do? Should I try and trade a gearset? Or do I want to run what I now have? If run what I have, which set and why? Thanks Tim
Re: Tranny dilemma~!
[Re: astjp2]
#1080134
09/22/11 02:52 AM
09/22/11 02:52 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I believe the 3.09 is a 6 cylinder gear and not that strong. plusw qa big drop to second. You have enough torque to sdtsay with a 2.45 or 2.46 there's little difference but a 4.10 gear would be the tickedt
home of the Sox and Martin Hemi Duster
[Re: astjp2]
#1080136
09/22/11 06:33 AM
09/22/11 06:33 AM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
The 2.45 or 2.66 1st gear will be fine for you. Big cubes, lots of torque down low. The 3.09 was a 6 cylinder trans only to get that little thing moving. I don't think it was any weaker than the others per se but you won't need that steep of a 1st, plus as Fred said, there is a bigger spread between 1st and 2nd.
[Re: astjp2]
#1080137
09/22/11 05:16 PM
09/22/11 05:16 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm a big fan of the 3.09 low gear for the street, I use 3.23 gears and get the same launch as 2.66 with 3.91's.
Sure there's a big drop between 1-2 but torque covers that.
[Re: astjp2]
#1080138
09/22/11 06:03 PM
09/22/11 06:03 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
3.55 gears? 8 3/4? I hope you don't plan on getting too crazy with the clutch and loud pedal. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: astjp2]
#1080146
09/25/11 04:36 PM
09/25/11 04:36 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Can you convert a 307 bearing case to a 308 bearing? TIm
Requires machining and maybe some welding because the 308 bore will hit the bolt holes .
Why do you want to switch to the larger bearing ?
[Re: Guitar Jones]
#1080149
09/25/11 07:04 PM
09/25/11 07:04 PM
Posts: 5,448 So Cal
Sinitro
So Cal
The 3.09 1st gear was also used for some of the 318 cars..
Just my $0.02...
