Page 1 of 3 1 2 3
055 & 054 '69 RADIATORS are they both 3-row rads? #1078259
09/19/11 03:33 PM
09/19/11 03:33 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
(Bob), what is/are the differences between a 2949055 and a 2949054 radiator.........(not just the number of rows if there is anything else)
I think my 055 is a 2-row radiator with space at the front for a condensor (maybe?).
Thanks,
Mike
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078260
09/19/11 07:39 PM
09/19/11 07:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
055 is a 2 row , 054 ... well you know
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078261
09/26/11 09:43 AM
09/26/11 09:43 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Mike,
The 055 also has a 12" trans cooler and the 054 has a 15" cooler. Other than the lower tank being bigger on the 054, thats it.
Bob
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: radiatorman] #1078262
09/26/11 10:09 PM
09/26/11 10:09 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
Bob,
sorry to have to ask you to clarify more, but I'm confused by what you and Johnrr said. Are you saying that the 054 originally is only a 2 row like the 055? Only difference is the lower tank? If you're "Glenn-Ray" Bob, thanks for the lower tank you just sent for my 70. Looks great. Tom
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: BLACKHEMIRR] #1078263
09/27/11 09:30 AM
09/27/11 09:30 AM
radiatorman Offline
radiatorman  Offline
Hey Tom,
Glad I could help with the tank! The 054 is a factory 3-row and the 055 is a factory 2-row.
Bob
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: BLACKHEMIRR] #1078264
09/27/11 02:05 PM
09/27/11 02:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bob,
I guess I should have not assumed that everyone knew that the 054 was a 3 row, that was just between Mike and myself.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: radiatorman] #1078265
11/15/11 10:25 PM
11/15/11 10:25 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Mike,
Bob
Mike, I don't know if you answered this before but is the 055 on your broadcast sheet?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: RoadRunnerJD] #1078266
11/16/11 03:46 AM
11/16/11 03:46 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Mike,
Bob
John the GTX is an "E" LA assembly plant car, no broadcast sheet but I'm 99% sure the 055 radiator is the original to the car, it is an original (nummbers matching) 3.54 Dana, 4-speed, 440 engine, even the original wheels and original spare. I think only the 4.10 Dana got the 054 radiator, saw an original 4.10 Dana 4-speed GTX at Mike's B/E&A get together a few years ago with the 054 (have photos....of course ) and another 3.54 Dana with a 055 at the Nat's too.
MikeR
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078267
11/16/11 09:13 AM
11/16/11 09:13 AM
Warrenton, VA
Warrenton, VA
I think I need to see a broadcast sheet to be convinced. I know the 383 with the A31 package came with an 054. I am sure that by high performance radiator they meant maximum cooling. The literature that I remember used the words maximum cooling system. The 055 also came with a different fan clutch for A/C. I know your car is very original but the 054 could have been switched for a different home at some point?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: RoadRunnerJD] #1078268
11/16/11 01:31 PM
11/16/11 01:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Wow, sounds like the factory could have saved us alot of trouble by using the words "3 row 26" rad" and "2 row 26" rad" on the axle package descriptions!
Need some broadcast sheets to put this one to bed boys.....
Mike, if you don't have any BS pics, I'm sure Dan, Doug or Barry do.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: RoadRunnerJD] #1078269
11/16/11 07:55 PM
11/16/11 07:55 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
John, I agree that the 054 came with the A31 High Performance Axle Package with the 3.91 8-3/4 and that's what camee with my '69 road runner I ordered in '69 but my '69 GTX is a 3.54 Dana which is the A33 Track Pak.
As for the radiator being switch I can't rule that out. The car title shows me as the third owner and it was almost completely original down to the wheels that still have a set of '70's or '80's BFG T/A radials with the original T/A tread patern. I'll post two photos of the engine in the car untouched with 93,000+ miles on it, one that my friend took when he was told about it and one that was on ebay at the same time as my friend was looking at it (that's another long crazy story too).
Let me know if it looks like an original radiator and if you can tell if it's an 054 or 055:
Photo from ebay no sale:
(Remember this is a California silenced car with no chrome tips either)
LOOK AT THE RADIATOR CAP AND THE DIRECTION OF THE OVERFOLW TUBE!!! NOTE THE ANGLE
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078270
11/16/11 08:05 PM
11/16/11 08:05 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The photo my friend took:
(Again note the angle of the overflow tube)
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078271
11/16/11 08:12 PM
11/16/11 08:12 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The 055 radiator now cleaned and painted, with the 305 8 (October 31, 1968) date code. The GTX has a C16/December 16, 1968 Scheduled Production Date so it is close enough to be the original and I still believe it is the original radiator to the car.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078272
11/16/11 08:25 PM
11/16/11 08:25 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
and here's a 054 LARGE FONT radiator in an A31 High Performance Axle package road runner (just like you said John ). And in this photo something should jump out at you that if the first two photos that I posted are of the original radiator, to my GTX then it is an 055 in the GTX
MikeR
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078273
11/16/11 11:32 PM
11/16/11 11:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
MikeR
What's that , the painted fendertag on a Lynch Rd. car ?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078274
11/16/11 11:39 PM
11/16/11 11:39 PM
Warrenton, VA
Warrenton, VA
Mike, it looks like an original radiator but it also looks like the motor is red? Was the motor pulled and repainted at one time? All I'm saying is that from what I see in the parts manual and in the description of the axle packages, the 055 is supposed to be an A/C radiator and a high performance (max cooling) radiator is standard with all the axle packages and should be an 054. It would be interesting to see some broadcast sheets for some GTX's like yours.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078275
11/16/11 11:54 PM
11/16/11 11:54 PM
Warrenton, VA
Warrenton, VA
The date code and radiator seem original but the 054 is the high performance radiator. Maybe for the A33, the description should have said simply a 26" radiator and they did not mean to describe it as a high performance radiator? I wonder if the 055 comes with the 3.55 8 3/4 axle package?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: DPelletier] #1078276
11/17/11 01:38 AM
11/17/11 01:38 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Basically ALL 383/440 optional axle packages (A31, A32, A34, A36), trailer towing (A35), Hemis and cop cars (BK or WK) got the 054.
A33 was 055.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: 69CoronetRT] #1078277
11/17/11 01:39 AM
11/17/11 01:39 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: 69CoronetRT] #1078278
11/17/11 01:51 AM
11/17/11 01:51 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
Page 1 of 3 1 2 3
