Pushrods? #1076000
09/16/11 05:10 PM
09/16/11 05:10 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
What causes them to smoke the ends around the cup area. I know that a lack of oil will but give me some more reason why this happens.Could to tight of a valve adjustment be the problem?Lets hear what u have lean..........Thax.
Re: Pushrods? [Re: racerx] #1076001
09/16/11 05:14 PM
09/16/11 05:14 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
No to lash adjustment , in my opinion. Just total lack of oil !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Pushrods? [Re: 65dragnet] #1076002
09/16/11 05:52 PM
09/16/11 05:52 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I'm was running a set of the Indy rocker arms,Made the switch to a set of the Harland sharps and looking at the feed holes on the Harland and the indie look to be the same,but i notice that the shaft on the Harland's have feed holes on the top/bottom of there shafts,I'm in need of a new set of push rods and trying to prevent this problem from reoccurring...Thax 4 the response
Re: Pushrods? [Re: racerx] #1076003
09/16/11 07:12 PM
09/16/11 07:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The do pushrod oiling, no more problems. That is what I am doing on my hemi. I will have plenty of oil in the top end for lubrication now. Tim
Re: Pushrods? [Re: racerx] #1076004
09/16/11 07:36 PM
09/16/11 07:36 PM
AndyF Offline
AndyF  Offline
Best thing to do is to use the correct lube when you put them together the first time. That gets them off to a good start. Then make sure that they get plenty of lube when running and you should be good to go.
Re: Pushrods? [Re: astjp2] #1076005
09/16/11 07:45 PM
09/16/11 07:45 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Explain please?
Thank you
Re: Pushrods? [Re: astjp2] #1076006
09/16/11 07:49 PM
09/16/11 07:49 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Please explain What did u do to increase the flow of oil?...
Re: Pushrods? [Re: AndyF] #1076007
09/16/11 07:58 PM
09/16/11 07:58 PM
NASHVILLE
NASHVILLE
What would "Correct Lube" be?
Thank you
Re: Pushrods? [Re: MAVERICKSHEMI] #1076008
09/16/11 08:40 PM
09/16/11 08:40 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
waiting
Re: Pushrods? [Re: racerx] #1076009
09/17/11 12:36 AM
09/17/11 12:36 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
No one asked, so I will...
What is your current setup? What heads, rockers, push rods, adjusters are utilized in this setup?
What type of driving? is this a race only setup? Does it spend any time at a idle when hot, like red light traffic? I have seen race cars do fine at the track, but the exact same setup on the street burns and smokes push rods. Lots and lots of factors can cause this. Lets say you have top notch stuff that is supplying plenty of oil up to the rocker gear. But the push-rods are about .100 too short. You have way to much adjuster hangout from the rocker arm. This can and will cause this.
A bad batch of adjusters can cause this, I recall one of the rocker companies, missing the heat treat on some of the parts causing adjusters to eat each other away.
With a stock setup, heads and lets say Iron Isky/Crane Ductile rockers, everything has to be in the ball park to work.. I have seen those rocker arms, not be drilled, or the oil hole be drilled in the wrong spot.
If your serious you can fix this on the cheap with a little sweat and a few skinned up knuckles. Run down or dig out a old stock set of valve covers. Cut the very top part, making a window so you can see whats going on. See where the oil is squirting etc. You could increase the size of this hole, banana groove the rockers for increased oiling..... Pull the cam and groove the 4th cam journal all the way around with a small .050 x .050 groove. This was always a trick the Hemi guys would do to oil the complicated valve gear on those. You could build a cheap spray bar oiling system (I did) out of 3/16 brake line feeding all the time straight from one of the oil galley plugs in the back of the block. Worked for my Jesel rocker arms, and 440-1 Indy heads. I was running 850 LBS open pressure turning 8Kand never once had a oiling issue to the valve train. And it was like $25 for the parts, of coarse most just buy the setup from Indy, which is in the $500 range last I checked. Think they wanted $350 to convert your supplied old covers to spray bar system.
Anyways, just some idea's to chew on. You really need to see whats going on, to find the problem and correct it. If you can get the system to oil good at idle with the engine/oil hot.. You wont need to worry again.
Re: Pushrods? [Re: racerx] #1076010
09/17/11 01:02 AM
09/17/11 01:02 AM
I have smoke the ends of some high dollar($23.00 each )pushrods because the pushrods where rubbing on the block preventing oil from getting between the rocker adjuster end and the pushrod cup It sounds like you have s set of Indy cylinder heads, what version and what ratio where the old rockers and what ratio are the new Harland Sharps? How many threads on the adjsusters are showing under the rocker arms? Make sure the pushrods are moving easily with the motor warmed with both valves closed, if this is a solid roller or solid flat lifter camshaft If hydraulic make sure they will move(spin) easily at zero lash I have one motor with Indy SR heads that uses T&D single shaft rockers and another motor with Indy 440-1 heads with single shaft Harland Sharp rockers, I had to grind on both heads to get pushrod clearances set up so they would live The quality of the pushrods makes a difference also, Manton Stage 3 and 5 are the best ones out there for high performance use I sell both Smith Bros and Mantons, I use Mantons in my motors
Re: Pushrods? [Re: racerx] #1076011
09/17/11 09:14 AM
09/17/11 09:14 AM
illinois
dodgeram1998 Offline
illinois
Here is an example of myself burning a pushrod recently with the car IDLING in my driveway LOL, putting on a different carburetor ,didnt set the idle at 1200+, car run for about 10 minutes trying to make adjustments , idle was in the neighborhood of 600-800 rpms( lower oil pressure and volume) smoked cylinder #2exhaust and broke cylinder#2 intake cup 440 roller cam harland sharp rocker springs 550lbs open lesson learned
Re: Pushrods? [Re: dodgeram1998] #1076012
09/17/11 06:12 PM
09/17/11 06:12 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
If you have a choice, which is the best way to go? Ball/ball or ball/cup?
TR Waters
Re: Pushrods? [Re: TrWaters] #1076013
09/17/11 07:12 PM
09/17/11 07:12 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Bob:it's te 440-1's
indy dove tail rockers
race only
Cab:1.5 indys ( Make sure the pushrods are moving easily with the motor warmed with both valves closed, if this is a solid roller or solid flat lifter camshaft )
when u say move freely y u meaning that the pushrod should spin freely
Thax....
Re: Pushrods? [Re: racerx] #1076014
09/17/11 07:23 PM
09/17/11 07:23 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I might be wrong, but he's probably talking about side clearance. Yes there should be some side clearance... maybe .010 or so.
This setup uses the Oiling line kit from Indy them? Have they been restricted already?
Re: Pushrods? [Re: Bob_Coomer] #1076015
09/17/11 07:26 PM
09/17/11 07:26 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
No....
Re: Pushrods? [Re: racerx] #1076016
09/17/11 07:39 PM
09/17/11 07:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
How is the rocker gear getting oil? Did Indy change the head design? My 440-1's does NOT oil the conventional way up through the cam tunnel from the #4 cam bearing journal...
Do these heads have little 1/8 NPT plugs in the side of the head near the back close to the end?
Re: Pushrods? [Re: Bob_Coomer] #1076017
09/17/11 07:47 PM
09/17/11 07:47 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yes Bob it has the little 1/8"npt fittings in the rear/front of the heads...
Re: Pushrods? [Re: racerx] #1076018
09/17/11 08:44 PM
09/17/11 08:44 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
so you are using the oiling lines from the back of the block to the heads right ?
Re: Pushrods? [Re: 65dragnet] #1076019
09/18/11 10:29 AM
09/18/11 10:29 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
That is correct..
