Re: Pushrods?
[Re: astjp2]
#1076005
09/16/11 07:45 PM
09/16/11 07:45 PM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
The do pushrod oiling, no more problems.
Explain please?
Thank you
Re: Pushrods?
[Re: astjp2]
#1076006
09/16/11 07:49 PM
09/16/11 07:49 PM
Posts: 4,068 Mo.
racerx
Mo.
The do pushrod oiling, no more problems. That is what I am doing on my hemi. I will have plenty of oil in the top end for lubrication now. Tim
Please explain What did u do to increase the flow of oil?...
Re: Pushrods?
[Re: AndyF]
#1076007
09/16/11 07:58 PM
09/16/11 07:58 PM
MAVERICKSHEMI
NASHVILLE
Best thing to do is to use the correct lube when you put them together the first time.
What would "Correct Lube" be?
Thank you
Re: Pushrods?
[Re: racerx]
#1076009
09/17/11 12:36 AM
09/17/11 12:36 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
No one asked, so I will... What is your current setup? What heads, rockers, push rods, adjusters are utilized in this setup? What type of driving? is this a race only setup? Does it spend any time at a idle when hot, like red light traffic? I have seen race cars do fine at the track, but the exact same setup on the street burns and smokes push rods. Lots and lots of factors can cause this. Lets say you have top notch stuff that is supplying plenty of oil up to the rocker gear. But the push-rods are about .100 too short. You have way to much adjuster hangout from the rocker arm. This can and will cause this. A bad batch of adjusters can cause this, I recall one of the rocker companies, missing the heat treat on some of the parts causing adjusters to eat each other away. With a stock setup, heads and lets say Iron Isky/Crane Ductile rockers, everything has to be in the ball park to work.. I have seen those rocker arms, not be drilled, or the oil hole be drilled in the wrong spot. If your serious you can fix this on the cheap with a little sweat and a few skinned up knuckles. Run down or dig out a old stock set of valve covers. Cut the very top part, making a window so you can see whats going on. See where the oil is squirting etc. You could increase the size of this hole, banana groove the rockers for increased oiling..... Pull the cam and groove the 4th cam journal all the way around with a small .050 x .050 groove. This was always a trick the Hemi guys would do to oil the complicated valve gear on those. You could build a cheap spray bar oiling system (I did) out of 3/16 brake line feeding all the time straight from one of the oil galley plugs in the back of the block. Worked for my Jesel rocker arms, and 440-1 Indy heads. I was running 850 LBS open pressure turning 8Kand never once had a oiling issue to the valve train. And it was like $25 for the parts, of coarse most just buy the setup from Indy, which is in the $500 range last I checked. Think they wanted $350 to convert your supplied old covers to spray bar system. Anyways, just some idea's to chew on. You really need to see whats going on, to find the problem and correct it. If you can get the system to oil good at idle with the engine/oil hot.. You wont need to worry again.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Pushrods?
[Re: racerx]
#1076010
09/17/11 01:02 AM
09/17/11 01:02 AM
Posts: 43,129 Bend,OR USA
Cab_Burge
I have smoke the ends of some high dollar($23.00 each )pushrods because the pushrods where rubbing on the block preventing oil from getting between the rocker adjuster end and the pushrod cup It sounds like you have s set of Indy cylinder heads, what version and what ratio where the old rockers and what ratio are the new Harland Sharps? How many threads on the adjsusters are showing under the rocker arms? Make sure the pushrods are moving easily with the motor warmed with both valves closed, if this is a solid roller or solid flat lifter camshaft If hydraulic make sure they will move(spin) easily at zero lash I have one motor with Indy SR heads that uses T&D single shaft rockers and another motor with Indy 440-1 heads with single shaft Harland Sharp rockers, I had to grind on both heads to get pushrod clearances set up so they would live The quality of the pushrods makes a difference also, Manton Stage 3 and 5 are the best ones out there for high performance use I sell both Smith Bros and Mantons, I use Mantons in my motors
Re: Pushrods?
[Re: TrWaters]
#1076013
09/17/11 07:12 PM
09/17/11 07:12 PM
Posts: 4,068 Mo.
racerx
Mo.
Bob:it's te 440-1's indy dove tail rockers race only Cab:1.5 indys ( Make sure the pushrods are moving easily with the motor warmed with both valves closed, if this is a solid roller or solid flat lifter camshaft ) when u say move freely y u meaning that the pushrod should spin freely Thax....
Re: Pushrods?
[Re: racerx]
#1076014
09/17/11 07:23 PM
09/17/11 07:23 PM
Bob_Coomer
Rock Springs
I might be wrong, but he's probably talking about side clearance. Yes there should be some side clearance... maybe .010 or so. This setup uses the Oiling line kit from Indy them? Have they been restricted already?
Re: Pushrods?
[Re: Bob_Coomer]
#1076015
09/17/11 07:26 PM
09/17/11 07:26 PM
Posts: 4,068 Mo.
racerx
Mo.
No....
Re: Pushrods?
[Re: racerx]
#1076016
09/17/11 07:39 PM
09/17/11 07:39 PM
Bob_Coomer
Rock Springs
How is the rocker gear getting oil? Did Indy change the head design? My 440-1's does NOT oil the conventional way up through the cam tunnel from the #4 cam bearing journal... Do these heads have little 1/8 NPT plugs in the side of the head near the back close to the end?
Re: Pushrods?
[Re: Bob_Coomer]
#1076017
09/17/11 07:47 PM
09/17/11 07:47 PM
Posts: 4,068 Mo.
racerx
Mo.
Yes Bob it has the little 1/8"npt fittings in the rear/front of the heads...
Re: Pushrods?
[Re: 65dragnet]
#1076019
09/18/11 10:29 AM
09/18/11 10:29 AM
Posts: 4,068 Mo.
racerx
Mo.
so you are using the oiling lines from the back of the block to the heads right ?
That is correct..
