Socketless Hose Ends #1074784
09/13/11 10:55 PM
09/13/11 10:55 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
I am researching socketless hose ends. I need to get a 90 and possibly a 45. 8-AN to socketless.
It seems like everything I run across is a solid one-piece fitting. I want to make sure I can position the hose end where I need it to be. Otherwise it will be dumb luck that it ends up where it needs to be as I tighten it down.
Am I reading the descriptions correctly or do these fittings actually "swivel" to allow positioning of the hose end?
http://www.summitracing.com/parts/FRA-209008-BL/?rtype=10
Oh, BTW, these fittings are expensive! Crazy.
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074785
09/13/11 11:01 PM
09/13/11 11:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I used all Aeroquipt and if you are asking if the nut turns separate from the fitting then yes they do
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074786
09/13/11 11:05 PM
09/13/11 11:05 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I bought a Fragola fitting once when I was in a pinch and it was the cheapest made junk I had ever seen.
I don't see anything about those fittings that indicate they will swivel after tightening down.
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074787
09/14/11 12:57 AM
09/14/11 12:57 AM
AndyF Offline
AndyF  Offline
They just twist on the hose after assembly. They'll be tight, but they will twist into position.
Re: Socketless Hose Ends [Re: dusturbd340W5] #1074788
09/14/11 08:32 PM
09/14/11 08:32 PM
Canton, Ohio
Canton, Ohio
That is what I am asking. Thanks.
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074789
09/14/11 09:13 PM
09/14/11 09:13 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Do not use socketless hose ends on transmission cooler lines ask me how I know. For low pressure low heat they are ok, now I prefer standard fittings. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Socketless Hose Ends [Re: Mopar_racer_99] #1074790
09/14/11 09:16 PM
09/14/11 09:16 PM
Kissimmee Fl.
Kissimmee Fl.
I am surprised you had a problem with them I have used them on a number of cars including cars driven on a regular basis and have never had an issue.
Re: Socketless Hose Ends [Re: dusturbd340W5] #1074791
09/14/11 09:32 PM
09/14/11 09:32 PM
Canton, Ohio
Canton, Ohio
Interesting...
Using them for fuel system, supply and return.
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074792
09/14/11 09:51 PM
09/14/11 09:51 PM
Kissimmee Fl.
Kissimmee Fl.
Interesting...
I would not worry about them at all i have used them on fuel,transmission fluid,and oil systems and have never had a failure.
I only use Aeroquip and this info is straight out of their catalog.
The socketless hose and fittings are rated at 250psi and a temp range from -40 to +300 degrees.
Re: Socketless Hose Ends [Re: Crazy68Dart] #1074793
09/14/11 10:45 PM
09/14/11 10:45 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
The swivel is the female nut used in the JIC(AN)connection.
Right after they are assembled you may be able to rotate the ends to get the configuration you are after. Don't get fooled and buy the assembly lube. All you need is some 80-90w gear oil. works great and is cheap.
If you use socketless hose for higher temp applications ,ie trans lines, it is recomended that a hose clamp is used (Aeroquip brand does not require the clamp if you use their AQP stuff). The heat will allow some other brands of hose to expand just enough and blow the end off. Otherwise, the socketless connection is rock solid and impossible to disassemble without cutting the hose off.
You can use industrial hose ends and save some serious coin versus using the "pretty" hose ends you listed.
Re: Socketless Hose Ends [Re: jb500] #1074794
09/14/11 11:48 PM
09/14/11 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the fuel area (production) we used a crimp ring
on that style of fitting... I will always be paranoid
of those without a clamp/crimp... but those have a
sharper/taller edge for the hose to bit on..... JMO
Re: Socketless Hose Ends [Re: MR_P_BODY] #1074795
09/15/11 01:13 AM
09/15/11 01:13 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
The FAST EZ EFI fuel pump kit comes with push lock hose and fittings. We will ad a keystone pinch clamp for security.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Socketless Hose Ends [Re: BradD] #1074796
09/15/11 09:13 AM
09/15/11 09:13 AM
Kissimmee Fl.
Kissimmee Fl.
Brad
I read somewhere that Aeroquip says do not use any kind of clamp as it can cut the inside of the hose.
