Socketless Hose Ends
#1074784
09/13/11 10:55 PM
09/13/11 10:55 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I am researching socketless hose ends. I need to get a 90 and possibly a 45. 8-AN to socketless. It seems like everything I run across is a solid one-piece fitting. I want to make sure I can position the hose end where I need it to be. Otherwise it will be dumb luck that it ends up where it needs to be as I tighten it down. Am I reading the descriptions correctly or do these fittings actually "swivel" to allow positioning of the hose end? http://www.summitracing.com/parts/FRA-209008-BL/?rtype=10Oh, BTW, these fittings are expensive! Crazy. Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: Socketless Hose Ends
[Re: Crazy68Dart]
#1074785
09/13/11 11:01 PM
09/13/11 11:01 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I used all Aeroquipt and if you are asking if the nut turns separate from the fitting then yes they do
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Crazy68Dart]
#1074786
09/13/11 11:05 PM
09/13/11 11:05 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I bought a Fragola fitting once when I was in a pinch and it was the cheapest made junk I had ever seen.
I don't see anything about those fittings that indicate they will swivel after tightening down.
[Re: Crazy68Dart]
#1074789
09/14/11 09:13 PM
09/14/11 09:13 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Do not use socketless hose ends on transmission cooler lines ask me how I know. For low pressure low heat they are ok, now I prefer standard fittings. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: dusturbd340W5]
#1074791
09/14/11 09:32 PM
09/14/11 09:32 PM
Crazy68Dart
Canton, Ohio
Interesting...
Using them for fuel system, supply and return.
[Re: jb500]
#1074794
09/14/11 11:48 PM
09/14/11 11:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
In the fuel area (production) we used a crimp ring on that style of fitting... I will always be paranoid of those without a clamp/crimp... but those have a sharper/taller edge for the hose to bit on..... JMO
[Re: MR_P_BODY]
#1074795
09/15/11 01:13 AM
09/15/11 01:13 AM
Posts: 543 Indiana, Just Off I-70
BradD
The FAST EZ EFI fuel pump kit comes with push lock hose and fittings. We will ad a keystone pinch clamp for security.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
