Billet rear main seal #1074549
09/13/11 08:41 PM
09/13/11 08:41 PM
illinois
dodgeram1998 Offline OP
illinois
I have a stock rear main seal that leaks oil urrrgghhh!! , 440 source main caps, the main caps studs didnt clear the stock seal retainer,, massaging was necessary. How well do these newer billet rear main seal retainers clear after market main caps/ and or studs ??,, in addition are folks happy how well the new billet piece seals.. thought about purchasing the Mancini racing billet ??
Thanks again moparts family
Re: Billet rear main seal [Re: dodgeram1998] #1074550
09/13/11 09:24 PM
09/13/11 09:24 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i have a indy one that i had to grind on to clear the studs.other than that it work's good. brad
Re: Billet rear main seal [Re: dodgeram1998] #1074551
09/13/11 09:28 PM
09/13/11 09:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How can the studs affect the seal retainer ... they are in the same location as the main bolts and are the same size. They may be longer but that will have nothing to do with the seal retainer.
Just out of curiosity, are you installing the retainer correctly - it only goes one way.
Re: Billet rear main seal [Re: Stanton] #1074552
09/13/11 09:41 PM
09/13/11 09:41 PM
illinois
illinois
Well if I remember correctly the retainer does interfere with studs on the mains,, dont have a picture to show otherwise however I do remember grinding (clearancing) on the retainer like it was yesterday ..
Re: Billet rear main seal [Re: Stanton] #1074553
09/13/11 09:44 PM
09/13/11 09:44 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Perhaps he is referring to the nuts on the studs rubbing the seal
If this is the case you should be able to clear it with 12 point nuts instead of the 6ers
Re: Billet rear main seal [Re: BIG BEAR] #1074554
09/13/11 09:50 PM
09/13/11 09:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used the one from Mancini for my 493 with ARP main studs and had to do a very small amount of grinding No big deal it's a custom part.
Gus
64 Plymouth Savoy
Dana 60
Re: Billet rear main seal [Re: dodgeram1998] #1074555
09/13/11 10:18 PM
09/13/11 10:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i used 1. had to grind down the studs. no big deal. if ur crank is knurled, it will still leak. oil seeps under the seal through the knurls. only cure for that is a rope seal. stay safe, seeya.
Re: Billet rear main seal [Re: dodgeram1998] #1074556
09/13/11 10:33 PM
09/13/11 10:33 PM
illinois
illinois
Thanks everyone , will have to order one tonite.
Re: Billet rear main seal [Re: dodgeram1998] #1074557
09/13/11 10:45 PM
09/13/11 10:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Shaft to bore concentricity and seal half alignment play a key role in weather the rear main will seal. Knurled shaft surfaces have little to do with sealing as long as there is not a groove wore in it.
Stock retainer and main stud nut interferance
Re: Billet rear main seal [Re: Stanton] #1074558
09/13/11 10:47 PM
09/13/11 10:47 PM
a493demon Offline
a493demon  Offline
i am talking about the top near the pan rail i had to grid for the studs not the seal area.it may have been changed since i bought mine 5 or 6 years ago and the stud's are longer than the bolt's . brad
Re: Billet rear main seal [Re: a493demon] #1074559
09/14/11 12:12 AM
09/14/11 12:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Without a pic I wouldn't have believed it. I have a 440Source retainer and it clears my studs/bolts just fine. I did have to ding the pan for stud clearance though. I could have ground the studs but didn't want to take them out and didn't want to grind them in the motor either.
Re: Billet rear main seal [Re: Stanton] #1074560
09/14/11 12:28 AM
09/14/11 12:28 AM
a493demon Offline
a493demon  Offline
mine was a indy and 440 sor. might have fixed /changed what indy did when they first made them.sorry i don't have any pic's. brad
