Billet rear main seal
#1074549
09/13/11 08:41 PM
09/13/11 08:41 PM
Posts: 312 illinois
dodgeram1998
illinois
I have a stock rear main seal that leaks oil urrrgghhh!! , 440 source main caps, the main caps studs didnt clear the stock seal retainer,, massaging was necessary. How well do these newer billet rear main seal retainers clear after market main caps/ and or studs ??,, in addition are folks happy how well the new billet piece seals.. thought about purchasing the Mancini racing billet ??
Thanks again moparts family
Re: Billet rear main seal
[Re: Stanton]
#1074553
09/13/11 09:44 PM
09/13/11 09:44 PM
Posts: 627 IN
BIG BEAR
IN
How can the studs affect the seal retainer ... they are in the same location as the main bolts and are the same size. They may be longer but that will have nothing to do with the seal retainer.
Just out of curiosity, are you installing the retainer correctly - it only goes one way.
Perhaps he is referring to the nuts on the studs rubbing the seal
If this is the case you should be able to clear it with 12 point nuts instead of the 6ers
[Re: BIG BEAR]
#1074554
09/13/11 09:50 PM
09/13/11 09:50 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used the one from Mancini for my 493 with ARP main studs and had to do a very small amount of grinding No big deal it's a custom part. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#1074558
09/13/11 10:47 PM
09/13/11 10:47 PM
Posts: 1,551 baldwinsville new york
a493demon
i am talking about the top near the pan rail i had to grid for the studs not the seal area.it may have been changed since i bought mine 5 or 6 years ago and the stud's are longer than the bolt's . brad
