Re: Moroso oil filter adapter
[Re: abodiesonly1]
#1074483
09/15/11 01:20 AM
09/15/11 01:20 AM
Posts: 4,072 Mo.
racerx
Mo.
Height: 2.80 inches Length: 5.10 inches Width: 4.10 inches
Found these specs....Hope it helps
Thax...
[Re: racerx]
#1074484
09/15/11 08:38 AM
09/15/11 08:38 AM
Posts: 4,072 Mo.
racerx
Mo.
Thax. 4 those dim. Anyone running a crank trigger with the pickup on the left side of the engine were the oil filter is?The problem I'm having is clearance problem between the filter and crank trigger pickup what r u guys doing to get around this problem pic's would be good.Thax....
[Re: '72CudaRacer]
#1074488
09/15/11 11:49 PM
09/15/11 11:49 PM
Posts: 4,072 Mo.
racerx
Mo.
One more
Thax... cudaracer is that a milladon pump cover? if so were u purchase it.Thax.
[Re: racerx]
#1074490
09/16/11 09:33 AM
09/16/11 09:33 AM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
One more
It is a Milodon oil pump cover, but you wouldn't know it by looking at it. No name or part number stamped or cast into it. I don't remember where I purchased it, probably Music City Rod Shop though, had it for a long time for another project and just started using it last year. If you go to Milodons web site they have a lot of pictures, just pick out what you need. I have a dual line swinging pick up, but I pluged one hole and just run a single #12 line to the oil pump cover. #10 lines to and from oil filter housing.
Brian Dunnigan
[Re: '72CudaRacer]
#1074491
09/16/11 09:52 AM
09/16/11 09:52 AM
Posts: 4,072 Mo.
racerx
Mo.
One more
Brian Dunnigan
Thax...I'll check it out...
