Milodon oil filter adapter #1074481
09/13/11 06:40 PM
09/13/11 06:40 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
http://www.summitracing.com/parts/MIL-21566/Application/?prefilter=1
Anyone use one?If so can u give me the dimensions?I've just installed a crack trigger with the pickup installed on the left side of the engine so i have to relocate the oil filter so i just need to get the thickness of this adapter......Thax.
Re: Moroso oil filter adapter [Re: racerx] #1074482
09/14/11 12:21 AM
09/14/11 12:21 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Height: 2.80 inches
Length: 5.10 inches
Width: 4.10 inches
Found these specs....Hope it helps
Re: Moroso oil filter adapter [Re: abodiesonly1] #1074483
09/15/11 01:20 AM
09/15/11 01:20 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Height: 2.80 inches
Length: 5.10 inches
Width: 4.10 inches
Thax...
Re: Moroso oil filter adapter [Re: racerx] #1074484
09/15/11 08:38 AM
09/15/11 08:38 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Height: 2.80 inches
Length: 5.10 inches
Width: 4.10 inches
Thax. 4 those dim.
Anyone running a crank trigger with the pickup on the left side of the engine were the oil filter is?The problem I'm having is clearance problem between the filter and crank trigger pickup what r u guys doing to get around this problem pic's would be good.Thax....
Re: Moroso oil filter adapter [Re: racerx] #1074485
09/15/11 07:44 PM
09/15/11 07:44 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Heres how I did mine Kerry.
Brian Dunnigan
Re: Moroso oil filter adapter [Re: '72CudaRacer] #1074486
09/15/11 07:46 PM
09/15/11 07:46 PM
Mooresburg, Tn
Mooresburg, Tn
next
Re: Moroso oil filter adapter [Re: '72CudaRacer] #1074487
09/15/11 07:46 PM
09/15/11 07:46 PM
Mooresburg, Tn
Mooresburg, Tn
One more
Re: Moroso oil filter adapter [Re: '72CudaRacer] #1074488
09/15/11 11:49 PM
09/15/11 11:49 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
One more
Thax... cudaracer is that a milladon pump cover? if so were u purchase it.Thax.
Re: Moroso oil filter adapter [Re: racerx] #1074489
09/16/11 12:16 AM
09/16/11 12:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
While your at it,install these pre-filters in the pick up lines.I also prefer oil filters with no by-pass.Moroso oil filters have no by-pass in them.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Moroso oil filter adapter [Re: racerx] #1074490
09/16/11 09:33 AM
09/16/11 09:33 AM
Mooresburg, Tn
Mooresburg, Tn
One more
It is a Milodon oil pump cover, but you wouldn't know it by looking at it. No name or part number stamped or cast into it. I don't remember where I purchased it, probably Music City Rod Shop though, had it for a long time for another project and just started using it last year. If you go to Milodons web site they have a lot of pictures, just pick out what you need. I have a dual line swinging pick up, but I pluged one hole and just run a single #12 line to the oil pump cover. #10 lines to and from oil filter housing.
Brian Dunnigan
Re: Moroso oil filter adapter [Re: '72CudaRacer] #1074491
09/16/11 09:52 AM
09/16/11 09:52 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
One more
Brian Dunnigan
Thax...I'll check it out...
