crank case evacuation systems???? #1072891
09/10/11 11:32 PM
09/10/11 11:32 PM
new york usa
P
pattyboy 572 Offline OP
P
new york usa
Crank case evacuation systems....do they work ...built 572 world block indy head..will these 35.00 systems work or will i need a 3 vane vacuum system any thoughts would be appreciated thanks pat( pump gas streetable ocassional track)
Re: crank case evacuation systems???? [Re: pattyboy 572] #1072892
09/12/11 08:45 AM
09/12/11 08:45 AM
farmingdale ny 11735
blracing Offline
blracing  Offline
if installed properly, they work. but a 572 may still need a vacume pump. put a vacume gauge on it and see what you have without the pump. then you can decide what to do.
Re: crank case evacuation systems???? [Re: pattyboy 572] #1072893
09/12/11 09:53 AM
09/12/11 09:53 AM
Guitar Jones Offline
I have the Moroso pan evac on my car but the aspirators it came with were too stiff, they didn't open. I used some off an old slant 6 Volare that open easier and it works fine now. I probably should put a pump on it but don't really have the money to spend on that right now.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: crank case evacuation systems???? [Re: pattyboy 572] #1072894
09/12/11 10:36 AM
09/12/11 10:36 AM
NC
440Jim Offline
440Jim  Offline
NC
I don't think the header evac systems work too well with mufflers behind them. But it can depend on the muffler, tail pipes, location, etc.
Re: crank case evacuation systems???? [Re: 440Jim] #1072895
09/12/11 03:16 PM
09/12/11 03:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The pan evac will work,but if it's in the budget get a vacume pump.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: crank case evacuation systems???? [Re: pattyboy 572] #1072896
09/12/11 05:04 PM
09/12/11 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A evac system can pull a MAX of 5"hg and if your exhaust
has more than 5" of back pressure all you will do
is burn out the valves on the evac and pressurize
the crank case... for every inch of back pressure
your exhaust has you will reduce the amount of vac
that can be pulled on the engine... there is a way
to do it with a evac but you need to mount it after
the muffler
