tranny cooler lines #1072868
09/10/11 11:18 PM
09/10/11 11:18 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Hey all,
My tranny cooler lines need replacing.
This may sound a little dumb, but I went to Autozone and they said they dont carry steel line that big...I thought that was weird.
So where do I get it? Can I only get like prebent expensive stuff? What are other options? Braided? dont want to go rubber....
Re: tranny cooler lines [Re: newbee69] #1072869
09/10/11 11:21 PM
09/10/11 11:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You ust have some real gems working there.Every parts store I go to has up to at least 3/8 steel line.We probally bought a few thousand rolls in the 30 years I was at the shops.Rocky
Chrysler Firepower
Re: tranny cooler lines [Re: newbee69] #1072870
09/10/11 11:33 PM
09/10/11 11:33 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Get some alum line ...
EZ install and it "cools" better.
Re: tranny cooler lines [Re: dOc !] #1072871
09/10/11 11:47 PM
09/10/11 11:47 PM
North Central Florida
E
eightlitermopar Offline
E
I believe in the past I have bought it from mancini or summit.
eight
Mopar or no car
Re: tranny cooler lines [Re: eightlitermopar] #1072872
09/10/11 11:57 PM
09/10/11 11:57 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
5/16" 5' sections of brake line from carquest
How is it that auto stores can't stock this stuff?
Re: tranny cooler lines [Re: newbee69] #1072873
09/11/11 12:12 AM
09/11/11 12:12 AM
I'd hit another parts house & get 2 prefabbed lengths of 5/16" steel lines w male inverted flare fittings on each end and in the "Edelman" brass fittings section (2) double female inverted flare fittings to connect the lines to the brass fittings already on the trans. As Doc said steel is hard 2 work w but you mainly just need a 90 deg bend at the trans on each line & can do it ahead of time on the vise w carefull use of the hot wrench w a small tip w just enough heat 2 make it slightly more pliable & make a wide enough radius so it does not crimp & some slight bending at the front depending on how much neoprene line you use. I.F. fittings seal on the concave/convex cone interface so give that a quick check on mockup
Re: tranny cooler lines [Re: RapidRobert] #1072874
09/11/11 10:43 AM
09/11/11 10:43 AM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
5/16 brake line is what used. Works great.
Re: tranny cooler lines [Re: 340Scamp] #1072875
09/11/11 07:44 PM
09/11/11 07:44 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I bought my set brand new off ebay for like $50. They are made by Inline Tube I think. Fit perfect right out of the box.
Scott
1969 Super Bee, 383/4 speed
