Page 2 of 3 1 2 3
Re: STROKER KITS [Re: gregsdart] #1072211
09/10/11 03:36 PM
09/10/11 03:36 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
While most well known shops will do a good job, I got burnt by two well known ones. The crank got thrown in a box and shipped without it being touched. Cost me over $250 to fix. The second time I ordered something from a long ways away, a machining step was skipped. So due to two problems out of two, never again. I want to be able to put it in the truck and go talk to them in person.
So on my eagle kit directly from them with hand writed balanced sheet I would think they didnt miss a step or they wouldnt be writen in right? Or do they just make stuff up to write in. My biggest problem was the rods didnt fit the pistons. I had to have the small end of the rod resized but the place I got the kit from compesated me for the cost of the machine work. I also broke a ring putting the pistons in and they sent me a new ring pack for free. And it was like a wholesale warehouse through my local parts store.
67' charger 499 RB 10.57 at 127
Re: STROKER KITS [Re: dragram440] #1072212
09/10/11 03:58 PM
09/10/11 03:58 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Depends on the rest of your build and intended usage. This is in the race section, not general, so that's going to up the ante.
Here's my take on this from a low-buck, mainly street stance.
Go with a balanced kit if:
You are building a street car that will rarely if ever be at full throttle, the engine will be assembled at home with basic tools and you are not checking every tolerance and fitting each part. The engine will be more for bragging rights and wanting a bit more than stock.
Go with the unbalanced if:
You or a good, trusted machinist is going to double or triple-check and fit each and every component, the engine will be run hard and long and expected to produce consistant and reliable high HP, and you will use all the available power.
Most people fall in between the cruiser bragging that he has a 400+ small block and idling around town and the racer that has a combo that puts others to shame. I would lean toward expecting that some fitting and changes will be needed on the rotating assembly. Stuff like ring fitting, bearing or piston coating, cleanup of clearances, rod bolt changes or smoothing of the piston tops can all change the weights of the components. It makes sense to do all of this fitting and setup before final balance to me.
I would also add that if you are taking a bunch of parts to a machinist, it makes sense to have them responsible for all the special work done. If the cost is fairly close, have them do the balancing too.
Re: STROKER KITS [Re: RodStRace] #1072213
09/10/11 04:08 PM
09/10/11 04:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My machinist checks everything at least 3 or 4 times.Then he checks it again.Last 2 blocks he did for us are fantastic.Rocky
Chrysler Firepower
Re: STROKER KITS [Re: RodStRace] #1072214
09/10/11 04:20 PM
09/10/11 04:20 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Every engine should be checked and double checked on all clearances if its a street engine or race engine. The machine shop checked everything and I double checked everything when I assembled it. If you are building a street engine you want it to last just as long as a race engine.
Re: STROKER KITS [Re: therocks] #1072215
09/10/11 04:24 PM
09/10/11 04:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My rotating assembly came from Dan, If he was closer I'd let him do my machine work too. There is a shop close to me that had been in business since the 60s and still going strong. Everything they've done for me has checked spot on.
Re: STROKER KITS [Re: justinp61] #1072216
09/10/11 04:53 PM
09/10/11 04:53 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i live near the guy that did the machineing and assembling and we are friends so i help him with his electrician needs.
he gets a lot of "balanced" rotating assemblys and sometimes his mesured weights and the written down ones are way off and the crank jumps around like mad with the their bob weight to just check quick.
it is my experience if you have a trusted shop then let them do the balance. a good shop will check the balance if they are going to be that guy anyway so why pay twice to do it correctly?
Re: STROKER KITS [Re: dmking] #1072217
09/10/11 05:06 PM
09/10/11 05:06 PM
K
KOS Online content
KOS  Online Content
K
how does 440source stack up?i figured with the amount of kits they sell they would have things pretty well figured out on the balancing aspect.
Re: STROKER KITS [Re: RodStRace] #1072218
09/10/11 07:14 PM
09/10/11 07:14 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
My duster is not a dailey driver but a strip/street car. My foot WILL be in it!!!! My 360 block is .040 so I dont know how many cubes it will make but Im not looking to set the world on fire. Id like to get a NICE 400+ SB with steel crank,H beam rods and forged pistons. I would use everything else in my current set-up to save money. I would thing with everything I have now in my 360 and then make it a 400+,I would think it would make at least 550HP and id be VERY happy with that!!!
I have PMed Dan and he has PMed me back...I will call him next week.
Re: STROKER KITS [Re: MIKES_DUSTER] #1072219
09/10/11 08:25 PM
09/10/11 08:25 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Glad to hear you got my subtle hint that you shouldn't expect out of the box to be perfect and that things should be done in order, not just slapped together.
dragram440, yes all precautions should be done and everything should be assembled with care, but sometimes there is the 'all I can afford' or the 'good enough, it's still better than factory' mindset. There will always be the dirt driveway rebuild at under a grand with a set of tools that came in a suitcase and a borrowed torque wrench. That guy needs a runner and can't afford the time and money to make everything perfect.
With the cost of stroker kits coming down to the point where it's almost as cheap as stock pistons, rings, bearings, a crank grind, reconditioning the rods and new bolts, some may decide to get one for a few bucks more and not be able to afford or do all the stuff that 'should' be done. Maybe it's a case like the member in South America where he can't find a decent local machine shop and shipping/import would be more than the parts.
Re: STROKER KITS [Re: RodStRace] #1072220
09/10/11 11:46 PM
09/10/11 11:46 PM
My 360 being .040, what kind of cubic inch could I get out of it?? Not like im looking for 500"!!!
Re: STROKER KITS [Re: MIKES_DUSTER] #1072221
09/11/11 06:26 AM
09/11/11 06:26 AM
Delray beach, Florida
P
Performance Only Offline
P
at 4.04 bore and a 4" stroke it becomes 410 inches of lean, mean, street strip machine.
machine shop owner and engine builder
Re: STROKER KITS [Re: Performance Only] #1072222
09/11/11 11:10 PM
09/11/11 11:10 PM
Is there any other size cranks besides a 4" and if so,what are they and how many cubes could you get??
Re: STROKER KITS [Re: MIKES_DUSTER] #1072223
09/11/11 11:14 PM
09/11/11 11:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mike I know you read dang near every thread in the race section so you know the answer to this. BPE makes a 4.125 and a 4.25.
68 Barracuda Formula S 340
Re: STROKER KITS [Re: Bad340fish] #1072224
09/11/11 11:19 PM
09/11/11 11:19 PM
Buy I dont know how many cubes it will make in my .040 360?? I dont know how to figure it out,sorry
Re: STROKER KITS [Re: MIKES_DUSTER] #1072225
09/11/11 11:22 PM
09/11/11 11:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The 4.25 would get you a 435
Save this link
http://www.wallaceracing.com/cid.php
they also have all kinds of other calculators that are fun to play with .
Re: STROKER KITS [Re: Bad340fish] #1072226
09/11/11 11:35 PM
09/11/11 11:35 PM
Thanks Clark!!!!!!
Re: STROKER KITS [Re: MIKES_DUSTER] #1072227
09/12/11 12:39 AM
09/12/11 12:39 AM
P
P
just be careful, i've seen more than one guy destroy a stock block. more stroke = more cubes but IMO the stock block will only handle the extra side loading for just so long.
Re: STROKER KITS [Re: MIKES_DUSTER] #1072228
09/12/11 08:38 AM
09/12/11 08:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Bore X bore X stroke X .7854 X the number of cylinders.
Re: STROKER KITS [Re: Performance Only] #1072229
09/12/11 10:05 AM
09/12/11 10:05 AM
Guitar Jones Offline
Please tell hard block and a main girdle will help.
I know I'm probably pushing the limit with a 4" stroke combo. The guy I got this cam from said they made 650 HP with it in a Super Stock 340 engine. I figure I have much better heads (W5), induction system (TR w/750's) and 60 more cubes so if I can't match his numbers I'm going quit.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: STROKER KITS [Re: Guitar Jones] #1072230
09/12/11 03:12 PM
09/12/11 03:12 PM
Thanks Justin!!!!
Just got off the phone with Dan. Very knowledgable and he was VERY patient with me and answered all my dumb questions!!!!! Thanks Dan.
Page 2 of 3 1 2 3
