Lets see your Turbo charged and supercharged Trucks #1070147
09/06/11 03:44 AM
09/06/11 03:44 AM
Iowa
76dodgeboy Offline OP
Iowa
Let see what you got
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070148
09/06/11 10:18 AM
09/06/11 10:18 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
My 2000 Dakota 5.9 with Powerdyne
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070149
09/06/11 10:20 AM
09/06/11 10:20 AM
Houston, Texas
Houston, Texas
My 94 Dakota 390 turbo
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070150
09/06/11 11:58 AM
09/06/11 11:58 AM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Turbo 94 dakota
supercharged 2000 r/t
2000 dakota 418 magnum paxton novi 2k T56
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070151
09/06/11 02:29 PM
09/06/11 02:29 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
64 D100 project. 440 D1SC. Lots of progress since this was taken. I should have the engine assembled this month. Then off to paint.
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Lets see your Turbo charged and supercharged Trucks [Re: 540CUDA] #1070152
09/06/11 03:11 PM
09/06/11 03:11 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
Rear view and instruments
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070153
09/06/11 04:07 PM
09/06/11 04:07 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
Instrument panel
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070154
09/06/11 06:23 PM
09/06/11 06:23 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Hey, I like that! What headers did you use, are those custom? What size turbo? If I could get some of those kinda parts, I would consider turboing my D100...Bet it would fly with your set-up.
Re: Lets see your Turbo charged and supercharged Trucks [Re: 540CUDA] #1070155
09/06/11 09:20 PM
09/06/11 09:20 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
440, Mopar 452 heads. Comp Hyd roller.
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070156
09/07/11 12:11 AM
09/07/11 12:11 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
'00 4.7 Dakota, 60-1 Hi Fi, A/W Intercooled.
http://members.cox.net/duner/Turbo/Scott%20L%20vs%20Duner.WMV
Re: Lets see your Turbo charged and supercharged Trucks [Re: 76dodgeboy] #1070157
09/07/11 12:16 AM
09/07/11 12:16 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
'99 R/T 5.9 Dakota, GT4202, A/W intercooled.
Was running a Vortech with A/W intercooler as well.
Re: Lets see your Turbo charged and supercharged Trucks [Re: Dragula] #1070158
09/07/11 09:30 AM
09/07/11 09:30 AM
Houston, Texas
Houston, Texas
It's a 76mm, stainless shorty headers flipped. A little bracket needed to be made to push the stock PS pump up about 3/8" on the driver's side.
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070159
09/09/11 01:52 AM
09/09/11 01:52 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
What ET? have you been to the track with the new set up yet? wanting to use a 76mm on mine also. BTW need more pics of the truck.
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070160
09/09/11 07:47 AM
09/09/11 07:47 AM
Do you have a better pic showing the headers and exhaust set-up on that? Would love to see how you adapted that to the shorties. I don't have any power steering, brakes, or anything like that in the way. I bet I could fit a pair of those on mine. If I could purchase over the counter headers and make those work, this would be an option for me.
Re: Lets see your Turbo charged and supercharged Trucks [Re: Dragula] #1070161
09/09/11 12:41 PM
09/09/11 12:41 PM
Houston, Texas
Houston, Texas
I went to the track earlier this year but had problems revving over 5000 rpms. It would go to 5000 fine, but then not pull past. It wouldn't bang, would't studder, just act like it hit a wall... I made only 1 "full" pass and went 11.7 @ 110. Had I shifted around 5000 I bet it would have run low 11's. Instead I kept it in gear waiting for it to rpm and it never would so then I would finally shift to 2nd and did the same thing shifting into 3rd. You can tell by my mph.. This was on about 5 lbs of boost.
For what its worth, a crank trigger solved that problem. I ran my buddies BBC truck that we think will run mid 11's based on the motor, weight of vehicle, etc. We ran each other, him on slicks me on drag radials. We both spun but by the top of 2nd gear I was up about 3 trucks and pulling when I got out of it. This is on only 4.5 lbs of boost and no intercooler at that time.
I dont have any other pics here at work, but they are just shorty headers flipped from side to side with the collectors cut and v-bands welded on. If you don't have any of those accessories, it should be an easy thing!
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070162
09/09/11 04:34 PM
09/09/11 04:34 PM
Please post a link to the turbo and which housing and flange....Would two of these be too much for say my 360? Or would I have to go to a 408?
Re: Lets see your Turbo charged and supercharged Trucks [Re: Dragula] #1070163
09/09/11 06:15 PM
09/09/11 06:15 PM
Houston, Texas
Houston, Texas
T4 flange, .89 AR housing. It will support 900 hp.
Would 2 be too much for your 360? What are your power goals?
Re: Lets see your Turbo charged and supercharged Trucks [Re: TheOtherDodge] #1070164
09/17/11 12:54 AM
09/17/11 12:54 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Here's mine!!
It's currently at BobsProFab.com
Re: Lets see your Turbo charged and supercharged Trucks [Re: DakFink] #1070165
09/20/11 07:33 PM
09/20/11 07:33 PM
MN
hemidup Offline
hemidup  Offline
MN
Here's mine. 2005 4x4 Dodge Ram Rumble Bee. 6.4/392 with a Paxton 1500 Novi supercharger.
Jerry Williams.
