Re: Lets see your Turbo charged and supercharged Trucks
[Re: 76dodgeboy]
#1070151
09/06/11 02:29 PM
09/06/11 02:29 PM
Posts: 617 Corvallis,OR
540CUDA
super street
super street
Corvallis,OR
64 D100 project. 440 D1SC. Lots of progress since this was taken. I should have the engine assembled this month. Then off to paint.
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
[Re: 540CUDA]
#1070152
09/06/11 03:11 PM
09/06/11 03:11 PM
540CUDA
super street
super street
Corvallis,OR
Rear view and instruments
[Re: TheOtherDodge]
#1070154
09/06/11 06:23 PM
09/06/11 06:23 PM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
My 94 Dakota 390 turbo
Hey, I like that! What headers did you use, are those custom? What size turbo? If I could get some of those kinda parts, I would consider turboing my D100...Bet it would fly with your set-up.
[Re: 540CUDA]
#1070155
09/06/11 09:20 PM
09/06/11 09:20 PM
540CUDA
super street
super street
Corvallis,OR
440, Mopar 452 heads. Comp Hyd roller.
[Re: Dragula]
#1070158
09/07/11 09:30 AM
09/07/11 09:30 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
It's a 76mm, stainless shorty headers flipped. A little bracket needed to be made to push the stock PS pump up about 3/8" on the driver's side.
[Re: TheOtherDodge]
#1070160
09/09/11 07:47 AM
09/09/11 07:47 AM
Dragula
Do you have a better pic showing the headers and exhaust set-up on that? Would love to see how you adapted that to the shorties. I don't have any power steering, brakes, or anything like that in the way. I bet I could fit a pair of those on mine. If I could purchase over the counter headers and make those work, this would be an option for me.
[Re: Dragula]
#1070161
09/09/11 12:41 PM
09/09/11 12:41 PM
TheOtherDodge
Houston, Texas
I went to the track earlier this year but had problems revving over 5000 rpms. It would go to 5000 fine, but then not pull past. It wouldn't bang, would't studder, just act like it hit a wall... I made only 1 "full" pass and went 11.7 @ 110. Had I shifted around 5000 I bet it would have run low 11's. Instead I kept it in gear waiting for it to rpm and it never would so then I would finally shift to 2nd and did the same thing shifting into 3rd. You can tell by my mph.. This was on about 5 lbs of boost.
For what its worth, a crank trigger solved that problem. I ran my buddies BBC truck that we think will run mid 11's based on the motor, weight of vehicle, etc. We ran each other, him on slicks me on drag radials. We both spun but by the top of 2nd gear I was up about 3 trucks and pulling when I got out of it. This is on only 4.5 lbs of boost and no intercooler at that time.
I dont have any other pics here at work, but they are just shorty headers flipped from side to side with the collectors cut and v-bands welded on. If you don't have any of those accessories, it should be an easy thing!
[Re: TheOtherDodge]
#1070162
09/09/11 04:34 PM
09/09/11 04:34 PM
Dragula
Please post a link to the turbo and which housing and flange....Would two of these be too much for say my 360? Or would I have to go to a 408?
[Re: DakFink]
#1070165
09/20/11 07:33 PM
09/20/11 07:33 PM
Posts: 833 MN
hemidup
MN
Here's mine. 2005 4x4 Dodge Ram Rumble Bee. 6.4/392 with a Paxton 1500 Novi supercharger.
Jerry Williams.
