Cuda window guides? See pic #1069379
09/04/11 08:55 PM
09/04/11 08:55 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Is one bent? Car is a 1972 Cuda. How and where do they mount? Thanks in advance
Re: Cuda window guides? See pic [Re: UCUDANT] #1069380
09/04/11 10:42 PM
09/04/11 10:42 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
The one on the left certainly seems bent. As for position, one goes on under the weatherstrip, with the round end exposed, where the door glass makes the turn on top. You can see one at the curve in this picture on Doug Lepak's site (click to get full sized picture)...
http://www.stwheelz.com/Gallery/index.php/Steering-Wheels-in-Customers-Cars/BarrelCuda
Re: Cuda window guides? See pic [Re: lahatte] #1069381
09/05/11 02:03 AM
09/05/11 02:03 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks I figured they were at the top front corner, could not recall. Does anyone repop them? I straightened the pinched one and may need to recoat it.
Re: Cuda window guides? See pic [Re: UCUDANT] #1069382
09/05/11 11:35 AM
09/05/11 11:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Cuda window guides? See pic [Re: gtx6970] #1069383
09/05/11 05:23 PM
09/05/11 05:23 PM
FRANCE, Paris
Chal340 Offline
Chal340  Offline
FRANCE, Paris
they are just under the weatherstrip or there is a hard setting?
70 Challenger, A66, 340 ci
Re: Cuda window guides? See pic [Re: Chal340] #1069384
09/05/11 05:46 PM
09/05/11 05:46 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Can you rephrase that?
Re: Cuda window guides? See pic [Re: lahatte] #1069385
09/06/11 04:51 AM
09/06/11 04:51 AM
FRANCE, Paris
Chal340 Offline
Chal340  Offline
FRANCE, Paris
Yes,
In fact I don't have these clips on my challenger and I would like to know if these clips are only under the weatherstrip without screws to fix them on the top?
Re: Cuda window guides? See pic [Re: Chal340] #1069386
09/06/11 08:02 AM
09/06/11 08:02 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
A window channel screw holds it in, so it's under the seal. If you can pull your seal down in the top front corner the install is a snap. So it's an anti rattle device
