Engine ping..3 part question. #1068391
09/03/11 10:30 AM
09/03/11 10:30 AM
Long Island NY
yellow sixpack Offline OP
Long Island NY
1. What is main cause for engine ping?
2. What will it do to your engine at low and fast acceleration?
3. And of course what is the best fix for it?
Thanks,Rob
If you can't be smart.....don't be stupid!
Re: Engine ping..3 part question. [Re: yellow sixpack] #1068392
09/03/11 10:51 AM
09/03/11 10:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thanks,Rob
I'll answer #2 ... it's beat your rod bearings to the copper, cause cap walk and possibly crack the block .
How about stating what your combo/timing is if you want an answer .
Re: Engine ping..3 part question. [Re: yellow sixpack] #1068393
09/03/11 11:03 AM
09/03/11 11:03 AM
W your curve in the ballpark you need enough octane to keep it at bay. (as you know) todays gas is very poor which forces u to compromise the curve which only helps a certain extent & causes other probs. Any ping you can hear is very damaging. If a person builds a monster it needs 2 b fed properly (a % of race gas)
Re: Engine ping..3 part question. [Re: RapidRobert] #1068394
09/03/11 02:42 PM
09/03/11 02:42 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
not to steal the post, what does ping feel, sound like. In other words, how do you know when the engine is pinging???
Re: Engine ping..3 part question. [Re: CUDAJAS] #1068395
09/03/11 02:56 PM
09/03/11 02:56 PM
Kirkland, Washington
Pacnorthcuda Offline
You step on the gas and instead of power you hear what sounds like a coffee can of marbles being shaken.
