Engine ping..3 part question.
#1068391
09/03/11 10:30 AM
09/03/11 10:30 AM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
1. What is main cause for engine ping? 2. What will it do to your engine at low and fast acceleration? 3. And of course what is the best fix for it? Thanks,Rob
If you can't be smart.....don't be stupid!
Re: Engine ping..3 part question.
[Re: yellow sixpack]
#1068392
09/03/11 10:51 AM
09/03/11 10:51 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Thanks,Rob
I'll answer #2 ... it's beat your rod bearings to the copper, cause cap walk and possibly crack the block .
How about stating what your combo/timing is if you want an answer .
#1068393
09/03/11 11:03 AM
09/03/11 11:03 AM
RapidRobert
W your curve in the ballpark you need enough octane to keep it at bay. (as you know) todays gas is very poor which forces u to compromise the curve which only helps a certain extent & causes other probs. Any ping you can hear is very damaging. If a person builds a monster it needs 2 b fed properly (a % of race gas)
[Re: CUDAJAS]
#1068395
09/03/11 02:56 PM
09/03/11 02:56 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
not to steal the post, what does ping feel, sound like. In other words, how do you know when the engine is pinging???
You step on the gas and instead of power you hear what sounds like a coffee can of marbles being shaken.
