How Much Slick Clearance is Required? #1066222
08/30/11 10:58 PM
08/30/11 10:58 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Went with the M/T 31 x 10.5W slick. It is about an inch taller than my old Phoenix tire.
How much minimum clearance should I have to the front lip to feel comfortable? This is a ladder bar car.
Re: How Much Slick Clearance is Required? [Re: markz528] #1066223
08/30/11 11:01 PM
08/30/11 11:01 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
1 1/2" or so Mark minimal.
Re: How Much Slick Clearance is Required? [Re: markz528] #1066224
08/31/11 01:14 AM
08/31/11 01:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
How wide are the rims are you mounting them on? I have the same size tire and brand mounted on 10 inch rims now with right at 1.25 inch clearance to the front lip, ran 129 MPH without rubbing with 4.10 gears The car is running 5 more MPH now that I switch heads and intake, I'm going to put them back on the car this weekend so I will see how that works out I'll also re measure them as I have also changed the rear end from a 8 3/4 to a Dana 60 so it may not be in the exact same location as before
Re: How Much Slick Clearance is Required? [Re: markz528] #1066225
08/31/11 01:20 AM
08/31/11 01:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As a quick check... if I can slip my palm in its good
so that about 1"... and thats at 150 mph
Re: How Much Slick Clearance is Required? [Re: MR_P_BODY] #1066226
08/31/11 08:50 AM
08/31/11 08:50 AM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
I always use 2 fingers but have seen less
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: How Much Slick Clearance is Required? [Re: MR_P_BODY] #1066227
08/31/11 09:18 AM
08/31/11 09:18 AM
ill
dennismopar73 Offline
ill
mr p ,,does radials 'grow' more over standarad slick??
i know in most cases, a tire will actually get more skinny' at speed, of course, but will the radial, or for that matter a stiff sidewall tire get bigger overall, ??
i runn a 33 /16.5 and i have around a 1-1 1/4 in the front,
but i havent had car out yet, all new so i'm thinking to run a smaller tire 32/14.5 w radial to increase my clearance, sure dont want to take out new quarters tire and paint ,
Re: How Much Slick Clearance is Required? [Re: dennismopar73] #1066228
08/31/11 12:49 PM
08/31/11 12:49 PM
Radials do not grow at speed like the bias plys do It probally depends on how wide the rim is , how much MPH the car runs and some other things like how much downforce is on the rear of the car at speed Does it raise the rear up at higher speed or does the downforce push it down at the finish line
Re: How Much Slick Clearance is Required? [Re: dennismopar73] #1066229
08/31/11 01:24 PM
08/31/11 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They dont grow much but also the front of the tire
doesnt see as much growth as the top
Re: How Much Slick Clearance is Required? [Re: MR_P_BODY] #1066230
08/31/11 02:08 PM
08/31/11 02:08 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I don't know why, but I have 1 1/4 inch clearance on the passenger side and 1/2 inch on the driver side. I knew there was a difference, but I never had an issue with it.
M/T tells me the tires will grow 1 1/2 inches @ 150 mph. My car runs 140 mph.
I checked the squareness of my rear to the front crossmember, and it is dead square. I guess I need to cut my driver quater panel.
Re: How Much Slick Clearance is Required? [Re: markz528] #1066231
08/31/11 09:21 PM
08/31/11 09:21 PM
NC
440Jim Offline
440Jim  Offline
NC
Wow.
Those tires grow a lot. I will have to actually measure, but my Pheonix slicks only have about 3/4" to the front lip and no problems. 14" wide rim with 13.6" tread, 143 mph.
Is M/T saying 1.5" radius or diameter change?
