How Much Slick Clearance is Required?
#1066222
08/30/11 10:58 PM
08/30/11 10:58 PM
Posts: 4,277 Morrow, OH
markz528
Morrow, OH
Went with the M/T 31 x 10.5W slick. It is about an inch taller than my old Phoenix tire.
How much minimum clearance should I have to the front lip to feel comfortable? This is a ladder bar car.
Re: How Much Slick Clearance is Required?
[Re: markz528]
#1066223
08/30/11 11:01 PM
08/30/11 11:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
1 1/2" or so Mark minimal.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: MR_P_BODY]
#1066227
08/31/11 09:18 AM
08/31/11 09:18 AM
Posts: 2,177 ill
dennismopar73
ill
mr p ,,does radials 'grow' more over standarad slick?? i know in most cases, a tire will actually get more skinny' at speed, of course, but will the radial, or for that matter a stiff sidewall tire get bigger overall, ?? i runn a 33 /16.5 and i have around a 1-1 1/4 in the front, but i havent had car out yet, all new so i'm thinking to run a smaller tire 32/14.5 w radial to increase my clearance, sure dont want to take out new quarters tire and paint ,
[Re: dennismopar73]
#1066228
08/31/11 12:49 PM
08/31/11 12:49 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Radials do not grow at speed like the bias plys do It probally depends on how wide the rim is , how much MPH the car runs and some other things like how much downforce is on the rear of the car at speed Does it raise the rear up at higher speed or does the downforce push it down at the finish line
[Re: MR_P_BODY]
#1066230
08/31/11 02:08 PM
08/31/11 02:08 PM
markz528
Morrow, OH
I don't know why, but I have 1 1/4 inch clearance on the passenger side and 1/2 inch on the driver side. I knew there was a difference, but I never had an issue with it.
M/T tells me the tires will grow 1 1/2 inches @ 150 mph. My car runs 140 mph.
I checked the squareness of my rear to the front crossmember, and it is dead square. I guess I need to cut my driver quater panel.
[Re: markz528]
#1066231
08/31/11 09:21 PM
08/31/11 09:21 PM
Posts: 16,928 NC
440Jim
NC
Wow. Those tires grow a lot. I will have to actually measure, but my Pheonix slicks only have about 3/4" to the front lip and no problems. 14" wide rim with 13.6" tread, 143 mph.
Is M/T saying 1.5" radius or diameter change?
