Turn signals on 69 dart
#1065422
08/29/11 10:58 PM
08/29/11 10:58 PM
Posts: 61 Minnesota
Mad Accountant
Minnesota
I finally put all the wiring in my 69 Dart, and now when I hit the right turn signal, all the turn signals flash like the hazards are on. Everything else works as it should, and the indicator lights on the dash indicate what should be happening, not what is. I disconnected the plug at the passenger side front signal, and when I hit the right blinker, only the right rear flashes, as it should, everything else is still OK. I plugged in half the of the plug to the front passenger side signal, and then everything works correctly, except no running light on the right front. I had to splice the wiring harness back together since someone had cut it up, but I made sure to match up all the correct wires. Obviously something is crossed, anyone have any ideas where to start looking? I thought maybe the switch, but the problem goes away when you disconnect the front passenger side. I thought maybe I crossed something when I repaired the harness, but should this affect the rear lights, too? Should I just jumper the driver's side running light wiring over to the passenger side and call it a day? I really, really hate electrical problems, since there is no hammer big enough
Re: Turn signals on 69 dart
[Re: Mad Accountant]
#1065426
08/30/11 11:06 AM
08/30/11 11:06 AM
RapidRobert
www.mymopar.com has colors/circuits. If the hazard sw is in the col I'd seperate the ts/brake white plastic pull apart connector in the dangling harness under the st col & ohm it & see if when you raise the TS stalk to signal a R turn if it makes continuity to the wires to the large filaments in all 4 corners the same as when you pull on the hazards & if so it would suggest a TS harness prob under the st wheel. If not in the col still somehow the R turn is feeding the hazard circuit (sounds like a crossed wire/circuit). I'd go over your circuits again starting w the R turn out from the col & locate where it is intersecting the upstream (input) side of the hazard sw if the large filaments in all 4 corners are being lit the same as if you pulled the hazard sw
