how do I remove a burned on headgasket? #1065111
08/29/11 03:51 PM
08/29/11 03:51 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
I have a 4 cyl head that the gasket is baked on and I am having a hard time scraping it off. Any suggestions or tips?
I am almost ready to put aircraft stripper on it but I am not sure about that.
Re: how do I remove a burned on headgasket? [Re: west] #1065112
08/29/11 04:07 PM
08/29/11 04:07 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
i use a really sharp wood chisel, and be really careful if the block or head is aluminum. Then i hit it with some 150 grit sand paper to take off the little bit thats left. Honda's are really bad about this.
Re: how do I remove a burned on headgasket? [Re: west] #1065113
08/29/11 04:30 PM
08/29/11 04:30 PM
need one of those round green discs that chuck onto your drill, forget what they are called/havent used one in years/hardware store would immed know
Re: how do I remove a burned on headgasket? [Re: west] #1065114
08/29/11 04:37 PM
08/29/11 04:37 PM
scratchnfotraction Offline
scotchbrite disc with the mini air angle grinder
i also like to use a stright wire brush thats about 1" round and very stiff in the mini grinder.
I use the brush to de-carbon the combustion chambers and valves before R&R them as well.
when the scotchbrite wont cut it then its to the wire brush or wire wheel.
use air to blow cyls clean or a shop vac them out.
they do make a spray gasket remover also,you can find it at napa for a few bux.
good luck and ez on the loony-um
Re: how do I remove a burned on headgasket? [Re: scratchnfotraction] #1065115
08/29/11 04:40 PM
08/29/11 04:40 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
I have scotchbrite pads and a wire wheel but was worried about keeping the surface flat.
I guess I'll just be careful. should be a fun day
Re: how do I remove a burned on headgasket? [Re: west] #1065116
08/29/11 04:44 PM
08/29/11 04:44 PM
I would not use the wire wheel, it will take off material. What Scratchn said they are scotchbrite sanding discs & are non metallic & do work well/fast. The gasket remover spray works fairly well if you let it set/work for 5 minutes but is nasty stuff 2 deal w
Re: how do I remove a burned on headgasket? [Re: west] #1065117
08/29/11 04:59 PM
08/29/11 04:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is it iron or aluminum?
First thing I'll try with a cly head is to use my heated pressure washer on it out in the parking lot. You get wet but the head get's clean.
I like to use these also if need be, got to be careful.
Some guys will come on here and tell you how they will screw things up?
Moderation works for me.
Re: how do I remove a burned on headgasket? [Re: Challenger 1] #1065118
08/29/11 05:21 PM
08/29/11 05:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Ship it out to the machine shop, have them deal with it, check the surface for flatness and pressure test it all at once!
Really, how much is your time worth?
P.S. Oven cleaner for short periods of time gets tough stuff off. Do not leave overnight!
Re: how do I remove a burned on headgasket? [Re: RapidRobert] #1065119
08/29/11 05:45 PM
08/29/11 05:45 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: how do I remove a burned on headgasket? [Re: hemi71x] #1065120
08/29/11 06:09 PM
08/29/11 06:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The green ones are made for aluminum.The regular disc can remove metal quick if you arent used to them.Ive seen a few guys grind aluminum parts deep trying to clean them with the reg discs.Use some green ones and be safe.Rocky
Chrysler Firepower
Re: how do I remove a burned on headgasket? [Re: therocks] #1065121
08/29/11 07:26 PM
08/29/11 07:26 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I had a thread about this a few months back.
Use the plastic bristle ones for anything to do with aluminum heads.
Re: how do I remove a burned on headgasket? [Re: west] #1065122
08/29/11 07:38 PM
08/29/11 07:38 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just remember, you CAN screw the surface up when using the roloc "cookies", on iron or aluminum. Don't go nuts, and keep all the debris clear of crankcase as you grind.
Re: how do I remove a burned on headgasket? [Re: RodStRace] #1065123
08/29/11 07:42 PM
08/29/11 07:42 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
my discs were not cutting it,I even tried aircraft stripper to no avail. I took your advice and am going to let the machinist deal with it.Thanks to you and everyone else that offered some help.
Re: how do I remove a burned on headgasket? [Re: west] #1065124
08/30/11 08:32 AM
08/30/11 08:32 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Give it one last shot soaking it with acetone and using a real gasket scraper. Cheap enough where it's dumb not to try.
It worked for me.
