Re: how do I remove a burned on headgasket?
[Re: west]
#1065113
08/29/11 04:30 PM
08/29/11 04:30 PM
RapidRobert
need one of those round green discs that chuck onto your drill, forget what they are called/havent used one in years/hardware store would immed know
[Re: west]
#1065114
08/29/11 04:37 PM
08/29/11 04:37 PM
Posts: 15,487 Florida
scratchnfotraction
scotchbrite disc with the mini air angle grinder i also like to use a stright wire brush thats about 1" round and very stiff in the mini grinder. I use the brush to de-carbon the combustion chambers and valves before R&R them as well. when the scotchbrite wont cut it then its to the wire brush or wire wheel. use air to blow cyls clean or a shop vac them out. they do make a spray gasket remover also,you can find it at napa for a few bux. good luck and ez on the loony-um
[Re: west]
#1065116
08/29/11 04:44 PM
08/29/11 04:44 PM
RapidRobert
I would not use the wire wheel, it will take off material. What Scratchn said they are scotchbrite sanding discs & are non metallic & do work well/fast. The gasket remover spray works fairly well if you let it set/work for 5 minutes but is nasty stuff 2 deal w
[Re: west]
#1065117
08/29/11 04:59 PM
08/29/11 04:59 PM
Challenger 1
Cincinnati, Ohio
Is it iron or aluminum? First thing I'll try with a cly head is to use my heated pressure washer on it out in the parking lot. You get wet but the head get's clean. I like to use these also if need be, got to be careful. Some guys will come on here and tell you how they will screw things up? Moderation works for me.
[Re: Challenger 1]
#1065118
08/29/11 05:21 PM
08/29/11 05:21 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Ship it out to the machine shop, have them deal with it, check the surface for flatness and pressure test it all at once! Really, how much is your time worth? P.S. Oven cleaner for short periods of time gets tough stuff off. Do not leave overnight!
[Re: hemi71x]
#1065120
08/29/11 06:09 PM
08/29/11 06:09 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
The green ones are made for aluminum.The regular disc can remove metal quick if you arent used to them.Ive seen a few guys grind aluminum parts deep trying to clean them with the reg discs.Use some green ones and be safe.Rocky
Chrysler Firepower
[Re: therocks]
#1065121
08/29/11 07:26 PM
08/29/11 07:26 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
I had a thread about this a few months back.
Use the plastic bristle ones for anything to do with aluminum heads.
[Re: RodStRace]
#1065123
08/29/11 07:42 PM
08/29/11 07:42 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
my discs were not cutting it,I even tried aircraft stripper to no avail. I took your advice and am going to let the machinist deal with it.Thanks to you and everyone else that offered some help.
[Re: west]
#1065124
08/30/11 08:32 AM
08/30/11 08:32 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Give it one last shot soaking it with acetone and using a real gasket scraper. Cheap enough where it's dumb not to try. It worked for me.
