E85, Alcohol, Or Racing gas.. #1062528
08/24/11 06:50 PM
08/24/11 06:50 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Which fuel is the most cost effective and provides the most bang for the buck as far as horse power vs cost this is taking all things into concideration like carb's, fuel systems, maintenance, fuel cost and anything I may be forgetting.
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062529
08/24/11 06:55 PM
08/24/11 06:55 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
E85....
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062530
08/24/11 06:56 PM
08/24/11 06:56 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
I started a post on this about 2 weeks ago.
Do A search on "Racing with E-85"
There is a lot of info in that thread. guyas here gave a wealth of info to me and its all there.
I will be racing with E-85 next year, thats how convinced I am.
search for it.
Re: E85, Alcohol, Or Racing gas.. [Re: bumps440] #1062531
08/24/11 07:11 PM
08/24/11 07:11 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I run it, my dad runs it, my new motor is being built for it.....
Re: E85, Alcohol, Or Racing gas.. [Re: joshking440] #1062532
08/24/11 07:50 PM
08/24/11 07:50 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Alcohol is hard to beat!!! Its cheap you can buy it anywhere,your engine will run cooler.I'm almost sure it makes the most power of the three. And if you need a little extra boost VP M5 will give you that.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: E85, Alcohol, Or Racing gas.. [Re: MRMOPAR622] #1062533
08/24/11 07:57 PM
08/24/11 07:57 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Although you have to add in the cost of plugs (if you are wanting to read them each weekend) and oil every so many runs.
Re: E85, Alcohol, Or Racing gas.. [Re: Diablo] #1062534
08/24/11 08:08 PM
08/24/11 08:08 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Ok this is what I am talking about....keep em' coming.
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062535
08/24/11 08:37 PM
08/24/11 08:37 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I have run 110 & 112 & 114 gas and Alcohol i have not run E85 but for me Alcohol is the way to go i love it because it makes more power and runs cooler and i can get it any time and i change my oil after about 6 races i use brad penn oil it`s green oil and you can boil it in a turkey cooker three or for times before you have to get new oil this is best oil i have used but if you get your carb right and use a lean out valve i don`t have much Alcohol in my oil and let them at the track try to burn me down ha ha ha they can`t and the hot weather don`t hurt the ET as much so good luck
Re: E85, Alcohol, Or Racing gas.. [Re: Diablo] #1062536
08/24/11 09:02 PM
08/24/11 09:02 PM
PA
moparacer Offline
moparacer  Offline
PA
My car might be atypical for alky use but I think I could run a entire season on 1 oil change and plugs..
I been changing it every 50 passes and I it looks new.
All year on 1 set of plugs too. I don't run top lube so that might help in that department.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: E85, Alcohol, Or Racing gas.. [Re: steeldust] #1062537
08/24/11 09:03 PM
08/24/11 09:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I got 950hp set up for e-85 and 12 gal of e-85 here. come get them and try it..
Re: E85, Alcohol, Or Racing gas.. [Re: VernMotor] #1062538
08/25/11 12:50 AM
08/25/11 12:50 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
We run alcohol, two cars with Flying Toilets on them. The our maintnence is no different than running gas. No extra plug changes, and oil is changed on the same frequency as when we ran gas. I don't see any negatives to running alcohol, unless winning rounds is a bad thing...
Curtis
Taking over the World one win light at a time.
Re: E85, Alcohol, Or Racing gas.. [Re: afxcoronet] #1062539
08/25/11 01:08 AM
08/25/11 01:08 AM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
SEEING THIS IS ATOPIC ON FUELS, NOT TO HIJACK YOUR THREAD.HOW DO THEY ALL PERFORM AT A HIGHER ALTITUDE,SAY 6000 FT IN COLORADO.WHICH WOULD BE A BETTER WAY TO GO.
Re: E85, Alcohol, Or Racing gas.. [Re: 2QUICK4U] #1062540
08/25/11 09:42 AM
08/25/11 09:42 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
it's alky for me!
Re: E85, Alcohol, Or Racing gas.. [Re: MegaDart] #1062541
08/25/11 09:57 AM
08/25/11 09:57 AM
Northeast Georgia
47hudson Offline
47hudson  Offline
Northeast Georgia
I have been running E-85 this year and love it. Super consistant, cheap, runs cooler, and you don't have to have a huge fuel system to deliver enough fuel, only about 20% more than gas. I spent $300.00 on a kit to convert my dominator carb and didn't change anything else. Still running a BG280 pump with -8 line to a dead head reg. I have had no issues and the car picked up atleast a 10th in the 1/8th mile! Check out raceone85.com
Re: E85, Alcohol, Or Racing gas.. [Re: Diablo] #1062542
08/25/11 12:35 PM
08/25/11 12:35 PM
gregsdart Offline
gregsdart  Offline
I use a lot of heat to keep the oil clear on methanol, warm to 200+ before shut down and be sure and crank it with ignition on/fuel off to fire what drips out of the lines.
Plugs, once checked, I go to the hotest one and tune by that to stay a tad rich, then I only need to check one plug if I make a tuning change.
Oil pan heater, or similar warming device will save fuel. Methanol is definitely the most powerful of the three, having more torque in the lower rpm ranges. I believe the differance is e85 is 2 percent better than gas, methanol about 2 percent better than e85, M5 by VP is faster yet but costly!
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062543
08/25/11 05:30 PM
08/25/11 05:30 PM
NC
440Jim Offline
440Jim  Offline
NC
I have run race gas, methanol, and E85 ethanol.
In many ways E85 is in between the other fuels:
- More torque than gas, not as much as methanol
- Runs cooler than gas, not as cool as methanol
- Uses more fuel than gas (~30%), but much less than methanol
- Changes ET less with weather than gas, but methanol may be slightly better. But all have been predictable for dial-in
- Less corrosive than methanol
- Less likely to milk the oil than methanol (but properly setup and operated is no problem with methanol)
The main reason I have been running E85 for 4 years is it saves money. Because you use so much methanol per run, the cost per run is higher than E85. And race gas is way, way more expensive than both, even though you burn less per run.
E85 was saving me $7 per day compared to methanol, and about $15 per day compared to race gas (110, forget 112 or 114 !) This year E85 is more expensive than previous years, but it still saves about $4/day compared to methanol.
A great fuel saver when running mechanical injection, is a pump gas primer/warm up system like Ron's "primer plus" http://killerrons.com
Re: E85, Alcohol, Or Racing gas.. [Re: 440Jim] #1062544
08/25/11 06:15 PM
08/25/11 06:15 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thanks guys, interesting info,,I am thinking about switching for next year as my winter upgrade, I have a 8082 dominator 2 circuit that I can have converted to E85 or Alky so I don't mess with my gas carb which seems to be working great.....keep them coming
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062545
08/25/11 08:15 PM
08/25/11 08:15 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I run Methanol. I like everything about it but the fumes.
Re: E85, Alcohol, Or Racing gas.. [Re: Mopar-Al] #1062546
08/26/11 09:25 AM
08/26/11 09:25 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Ya but it kills the bugs!
Dartman, that is the best thing to do. Keep your tried and true gas carb and send the other out for conversion. I highly recommend George Rupert if you go alky.
Just to follow up on Jim's fuel consumption, he was using constant flow injection. Switching from gas carb to an alky carb you will use about 25% more on raceday.
My Dart runs 5.2x/8.2x and uses approx. 1gal for 1/8mile pass including all warmups, driving up and back, etc.
1/4mile uses approx. 1.5gal. With a Rupert 1250cfm.
Injection will double your fuel consumption.
Re: E85, Alcohol, Or Racing gas.. [Re: MegaDart] #1062547
08/26/11 10:30 AM
08/26/11 10:30 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
MegaDart you are right about the injection it does use a little more.
That was also some great advice on having someone who knows what they are doing set his carb. up.
M5 is $270.00 & M1 is $170.00 per drum,the M5 will not only boost you power but will bring tears to everyone eyes around your car.
