Page 2 of 3 1 2 3
Re: Getting sick of the stroker - question about downsize [Re: ahy] #1059509
08/22/11 10:39 PM
08/22/11 10:39 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'll trade you my 360 cu. in. rotating assembly for your 408 cu in rotating assembly.
you keep your block, heads, cam, etc. and I'll keep my block heads and cam (magnum vs presumably, an LA based build on your end?)
you'll get streetability of a stock stroke engine, I get a 408.
win-win!!! (my 360 magnum is fresh, zero miles)
**Photobucket sucks**
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059510
08/22/11 11:15 PM
08/22/11 11:15 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
While my 414 has a real rough idle it is smoother and quieter when cruising due to being balanced and a properly matched combo. I also run a 2500 stall converter and it does not need more than that. Go back to stock stroke? Not me. I would cam your stroker for street manners if that is what you want. Then you will have the torque of a stroker with the mild manners you are seeking. For a street car a stroker is the way to go. Torque to get that heavy car off the line without the need for big gears, big converters, or big cams.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059511
08/23/11 02:56 AM
08/23/11 02:56 AM
AndyF Offline
AndyF  Offline
Just put a smaller cam in it and maybe a smaller carb. We used a small roller cam in Tim's 427 small block with a 650 Holley carb. Sure it gave up some top end power, but it idles smooth at 800 rpm and still rips the snot out ya when you stomp on it.
The cam I used was about 20 degrees smaller than what the internet experts suggested. The carb was also a ton smaller than what people recommended. I knew that if I followed the normal advice I'd end up with a lumpy, peaky motor that fouled plugs and wasn't any fun to drive.
Re: Getting sick of the stroker - question about downsize [Re: AndyF] #1059512
08/23/11 08:10 AM
08/23/11 08:10 AM
Maryland
wally426ci Offline OP
Maryland
It definitely helps me to get feedback from everyone.
I will openly take recommendations on cam specs here. I went from a Racer brown cam to a Comp cam. I hear good things about Lunati.
I like the sound of keeping my existing parts for the most part.
Re: Getting sick of the stroker - question about downsi [Re: stumpy] #1059513
08/23/11 08:12 AM
08/23/11 08:12 AM
crlush Offline
crlush  Offline
Recam and detune the stroker. Unless you are running huge compression it's just a bigger cube engine in the long run.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059514
08/23/11 09:00 AM
08/23/11 09:00 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I have the same issue with my 496" RB stroker. It was a ball at first but really a PITA to cruise in. I changed the headers back to manifolds, de-cammed, took off the 6 pack in favor of a 750 vacuum carb setup on a TM7, replaced the tach drive distributor with a stock vacuum advance unit, pulled the 727 and 3800 convertor in favor of a 4 speed, and replaced the 4.10 with a 3.23. It is a lot more pleasureable now, but I think that I should still change the big valve heads and TM7 out this winter. The "street race" performance has take a major hit, but I haven't honestly had a real street race in 40 years or so.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059515
08/23/11 02:22 PM
08/23/11 02:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think you need to state exactly what cam you have now to use as a benchmarks of what you don't want.
Still, this is all assuming the car has some decent tune right now. And that it's the cam that's making it rough as opposed to a bad tune, bad part, or something that needs to be repaired.
Re: Getting sick of the stroker - question about downsize [Re: autoxcuda] #1059516
08/23/11 05:46 PM
08/23/11 05:46 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Jeff Patterson built me a nice mild 408 stroker (.484 lift) for my 68 Charger. It is the wifes car so it had to be street friendly. I run A/C, and Power Steering, a nice street friendly edelbrock 800 and it only has a 2.94 gear. I took it to the track once and got a 13.28 out of it. I think it would run a 12.90 if I worked at it. Starts up nice in the cold and doesn't have a rich exhaust smell. Drove it up to the Woodword Dream cruise from Ohio and at 70mph, it was at a reasonable rpm. Keep your engine and change the cam and a few other things and you will enjoy the torque.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059517
08/23/11 05:51 PM
08/23/11 05:51 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
if You do the math on gas mileage alone, You aren't saving much and what's the recovery cost down sizing to a "PUTTER". I had a 498 stroker and it lumped at lights but pulled away without hesitation and NEVER lost a street drag to anything. I'm kicking Myself for getting rid of it. My 2 cents on life and old hot cars is " if it looks good;it BETTER haul ass" 318 is a nice dependable motor but a boat anchor for drags. (that should open up another topic)
SO...My next car will not have a 498 stroker.....512 is on the horrizon......hmmmm....can You say "neck snap"...lol
Re: Getting sick of the stroker - question about downsize [Re: rapom] #1059518
08/23/11 06:31 PM
08/23/11 06:31 PM
Connecticut
FurryStump Online content
FurryStump  Online Content
Connecticut
Just put in a soild lifter cam from him, very happy,very nice guy
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Getting sick of the stroker - question about downsize [Re: FurryStump] #1059519
08/24/11 11:06 AM
08/24/11 11:06 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Maybe you just need a real good tune on it.
Maybe pitch that 750 for a better design. Never read about anyone happy with them. 800AVS?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Getting sick of the stroker - question about downsize [Re: Rug_Trucker] #1059520
08/25/11 12:28 AM
08/25/11 12:28 AM
KY
b5a12bee Offline
b5a12bee  Offline
KY
I love my 408, it has a small hydrolic roller cam with indy max heads with 3.73 gears. Runs very strong and very street frienly.
Re: Getting sick of the stroker - question about downsize [Re: b5a12bee] #1059521
08/25/11 11:52 AM
08/25/11 11:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yeah, most people suggest too much duration for a stroker that is going to be used on the street, IMHO
dump the 750 eddie, I'd go with an 800 eddie, or a demonsizzler built t-quad. I know on my 360, I gained a ton of drivability and 2" of idle vaccuum switching from the 750 eddie to a 600. there's a lot of info on the web of people never getting the 750 to run good...sounds like there's a flaw in the design of the internal passages of that carb
intake, Eddie RPM or air gap for a square bore carb, probably a eddie LD340 modded for the t-quad, if you can't find one, probably a weiand action plus, or maybe an M1 single plane (hard to find good spead bore mopar intakes)
for a cam, I'd use the lunati voodoo 60403 if you want to stick to a flat tappet.
fresh heads, a good 5 angle VJ, maybe some home porting opening up the bowls and pushrod pinch
should have a very strong, yet mellow engine that should idle at 800 RPM with probably 14" vaccuum
2017 Grand Cherokee Overland
Re: Getting sick of the stroker - question about downsize [Re: patrick] #1059522
08/26/11 12:44 AM
08/26/11 12:44 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
Stick a stock 318 back in!! I am willing to trade you 2 for your stroker, even up. And I will deliver!!!
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: Getting sick of the stroker - question about downsize [Re: 75DART440] #1059523
08/26/11 11:53 AM
08/26/11 11:53 AM
Maryland
Maryland
Too funny.
I am years away from taking it off the road as our 2nd daughter is due in October.
I am leaning toward downsizing the carb, changing heads, cam, converter.
Right now I am running a 68 340 cast iron intake.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059524
08/26/11 10:50 PM
08/26/11 10:50 PM
Kansas
Menzaero Offline
Menzaero  Offline
Kansas
Keep the stroker - I have a mild 418 in my Dart with good performance and 14 to 15 MPG if I keep my foot out of it crusing around town.
10.1 CR (Ross 16cc Dish Pistons)
800 AVS Edelbrock on a Performer RPM
X-Heads (69.3cc) and stock exhaust
XE 274H Comp Cam (230/236 - .488/.491)
3:55 Gear
Here is a Youtube link - http://www.youtube.com/watch?v=DrKBbVmQVf0
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059525
08/26/11 11:41 PM
08/26/11 11:41 PM
IN
ahy Offline
ahy  Offline
IN
Too funny.
I'm just curious... what is the issue with the heads? What's the benefit of changing?
Re: Getting sick of the stroker - question about downsize [Re: ahy] #1059526
08/27/11 01:47 AM
08/27/11 01:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I want to know as well. Heads won't make that much difference on the final driveability you seek.
I agree with everyone else, you need to pick a proper cam, install and degree it and you should be fine. I drove my 440 car everywhere before I pulled it apart and it was no problem.
Re: Getting sick of the stroker - question about downsize [Re: DaytonaTurbo] #1059527
08/27/11 01:51 AM
08/27/11 01:51 AM
vashon island washington
hunterstroble Offline
What about fuel injecting it? Just a thought.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Getting sick of the stroker - question about downsize [Re: hunterstroble] #1059528
08/27/11 04:19 AM
08/27/11 04:19 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
Did you consider swapping to a late model hemi (5.7/6.1)? You would get EFI and excellent driveability, as well as good mileage. As a bonus, with the 6.1 you would get the same or more power! It will bolt right in with readily available parts. I've done it, no regrets!
Page 2 of 3 1 2 3
