Good reasonable machine shop Pittsburgh area #1059308
08/22/11 10:21 AM
08/22/11 10:21 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
My engine broke the other day. Does anyone know of a good, and resaonably priced machine shop in the south hills area of Pittsburgh,Pa.?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Good reasonable machine shop Pittsburgh area [Re: 68LAR] #1059309
08/22/11 10:23 AM
08/22/11 10:23 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sorry to hear, what happened?
Re: Good reasonable machine shop Pittsburgh area [Re: Thumperdart] #1059310
08/22/11 10:32 AM
08/22/11 10:32 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I toke it for a test ride after doing some transmission work on Saturday. On the way back home, I noticed the temp starting to climb, then it started to knock real bad. I tore the engine appart and found #6 cylinder has a 2" crack in it. Water got into the oil and I guess when it did, it toke out #6 &#5 rods, both are junk, also #6 piston hit the head, and it is toast also. So as of now, I'm looking to get the block sleeved, 2 rods and 1 piston. Really strange thing is this engine was put together in 2004 and it NEVER over heated or had any issues. Just my luck I guess.
Re: Good reasonable machine shop Pittsburgh area [Re: 68LAR] #1059311
08/22/11 11:04 AM
08/22/11 11:04 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
DLK in Russelton isn't to far from you and does great work. Talk to Jeff. 724-265-1020. PM me if you need anything to get her running again.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Good reasonable machine shop Pittsburgh area [Re: pittsburghracer] #1059312
08/22/11 11:13 AM
08/22/11 11:13 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Im sure Bob George could help you out.
Re: Good reasonable machine shop Pittsburgh area [Re: HEMIDARTS] #1059313
08/22/11 03:05 PM
08/22/11 03:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Bob Georege is in I believe 84 Pa.If you want to drive an hour there is a great small shop in Girard Ohio that I use exclusively.He isnt fast but is reasonable and a perfectionist.You might be cheaper getting a stroker kit.By the time you turn, polish crank,recon all the rods and replace at least 2 and find a piston.Adds up fast.That and Id replace all the rod bolts with ARPs.Rocky
Chrysler Firepower
Re: Good reasonable machine shop Pittsburgh area [Re: therocks] #1059314
08/22/11 10:32 PM
08/22/11 10:32 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
How about Bob George, or Bowman Performance? I have heard good things about both.
Re: Good reasonable machine shop Pittsburgh area [Re: HEMIDARTS] #1059315
08/22/11 10:45 PM
08/22/11 10:45 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: Good reasonable machine shop Pittsburgh area [Re: 68LAR] #1059316
08/22/11 11:13 PM
08/22/11 11:13 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Jake Savani, Savani Auto Machine 412-678-9220, He is in McKeesport Pa. I have no complaints, He does the Machine Work for a lot of Guys that build Engines on this Sight
Re: Good reasonable machine shop Pittsburgh area [Re: Mpetros] #1059317
08/23/11 01:27 AM
08/23/11 01:27 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Savani is where mine went Larry. That isn't good news. It must be the Nats curse, but a week late. First Jr., then JJ, now you!
Re: Good reasonable machine shop Pittsburgh area [Re: 68LAR] #1059318
08/23/11 01:35 AM
08/23/11 01:35 AM
houma,la
joe teuton Offline
joe teuton  Offline
houma,la
Go to ray barton not that far away.
Re: Good reasonable machine shop Pittsburgh area [Re: Mpetros] #1059319
08/23/11 02:31 AM
08/23/11 02:31 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Jim Evanuik in North Versailles is good as well.
Re: Good reasonable machine shop Pittsburgh area [Re: sixpakdodge] #1059320
08/23/11 08:59 AM
08/23/11 08:59 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks for the replies. I toke it to Savani's yesterday.
