Good reasonable machine shop Pittsburgh area
#1059308
08/22/11 10:21 AM
08/22/11 10:21 AM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
My engine broke the other day. Does anyone know of a good, and resaonably priced machine shop in the south hills area of Pittsburgh,Pa.?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Good reasonable machine shop Pittsburgh area
[Re: 68LAR]
#1059309
08/22/11 10:23 AM
08/22/11 10:23 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Sorry to hear, what happened?
[Re: Thumperdart]
#1059310
08/22/11 10:32 AM
08/22/11 10:32 AM
68LAR
South Park, Pa.
I toke it for a test ride after doing some transmission work on Saturday. On the way back home, I noticed the temp starting to climb, then it started to knock real bad. I tore the engine appart and found #6 cylinder has a 2" crack in it. Water got into the oil and I guess when it did, it toke out #6  rods, both are junk, also #6 piston hit the head, and it is toast also. So as of now, I'm looking to get the block sleeved, 2 rods and 1 piston. Really strange thing is this engine was put together in 2004 and it NEVER over heated or had any issues. Just my luck I guess.
[Re: 68LAR]
#1059311
08/22/11 11:04 AM
08/22/11 11:04 AM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
DLK in Russelton isn't to far from you and does great work. Talk to Jeff. 724-265-1020. PM me if you need anything to get her running again.
[Re: HEMIDARTS]
#1059313
08/22/11 03:05 PM
08/22/11 03:05 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Bob Georege is in I believe 84 Pa.If you want to drive an hour there is a great small shop in Girard Ohio that I use exclusively.He isnt fast but is reasonable and a perfectionist.You might be cheaper getting a stroker kit.By the time you turn, polish crank,recon all the rods and replace at least 2 and find a piston.Adds up fast.That and Id replace all the rod bolts with ARPs.Rocky
Chrysler Firepower
[Re: Mpetros]
#1059319
08/23/11 02:31 AM
08/23/11 02:31 AM
Posts: 4,101 Yes
sixpakdodge
Yes
Jake Savani, Savani Auto Machine 412-678-9220, He is in McKeesport Pa. I have no complaints, He does the Machine Work for a lot of Guys that build Engines on this Sight
Jim Evanuik in North Versailles is good as well.
[Re: sixpakdodge]
#1059320
08/23/11 08:59 AM
08/23/11 08:59 AM
68LAR
South Park, Pa.
Thanks for the replies. I toke it to Savani's yesterday.
