Need to go faster #1058914
08/21/11 10:15 PM
08/21/11 10:15 PM
Peru
cbarracuda Offline OP
Peru
My car runs 9.97 best, usually low tens, need to go 9.30 to beat a Subaru. I need a good system of NOS. Big money on the bet. My car is a small block 12 to 1 compression W2. Is it posible?
Re: Need to go faster [Re: cbarracuda] #1058915
08/21/11 10:18 PM
08/21/11 10:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
at 3000lb you need 225 more hp to go 9.00
Re: Need to go faster [Re: cbarracuda] #1058916
08/21/11 10:19 PM
08/21/11 10:19 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Put a nice big block together and you won't need the NOS.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need to go faster [Re: pittsburghracer] #1058917
08/21/11 10:25 PM
08/21/11 10:25 PM
Peru
Peru
Hey I said I wanted to go faster not slower
Re: Need to go faster [Re: sixpackgut] #1058918
08/21/11 10:27 PM
08/21/11 10:27 PM
Peru
Peru
Donīt you think the compression is too high for those many HP with squeeze
Re: Need to go faster [Re: cbarracuda] #1058919
08/21/11 10:32 PM
08/21/11 10:32 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i dont think so but i'm no expert. you wanted to know what you needed, i ran the numbers and told you. if you have a stock block, that could be its end so its something to think about
Re: Need to go faster [Re: sixpackgut] #1058920
08/21/11 10:46 PM
08/21/11 10:46 PM
gregsdart Offline
gregsdart  Offline
Going from 10.00s to 9.20s is a big move. It is not just having the power, it is getting it to the ground as well. It takes a minimum of 770 hp to break into the 9.20s at 3,000 lbs, and a well tuned suspension/chassis. 725 Hp will get you 9.30s at 3,000. How deep are you in this?
Re: Need to go faster [Re: cbarracuda] #1058921
08/21/11 10:46 PM
08/21/11 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Guys run big compression with spray... just have to have
the tune up right
Re: Need to go faster [Re: gregsdart] #1058922
08/21/11 10:57 PM
08/21/11 10:57 PM
Peru
Peru
The suspension is ok but I race with SS springs, it might start spinning. My tires are 33 inches tall and rear end gears 4.89, I have 4.30 and 3.90, I would have to change the gears for this race and I belive the 3.90 for top end. Right now I croos the finish line at 7200 rpm
Re: Need to go faster [Re: MR_P_BODY] #1058923
08/21/11 10:58 PM
08/21/11 10:58 PM
Peru
Peru
the tune up right
what would be the right tune up?
Re: Need to go faster [Re: sixpackgut] #1058924
08/21/11 11:10 PM
08/21/11 11:10 PM
Peru
Peru
Yes it is stock block 1971 360. The car weights 2800 with me in it. I only need to go 9.40, this guy is slow on the tree so I was thinking 175 HP off squeeze
Re: Need to go faster [Re: cbarracuda] #1058925
08/21/11 11:27 PM
08/21/11 11:27 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I think if you spray that much on a stock block you're gonna end up with a bunch of pieces...
Re: Need to go faster [Re: cbarracuda] #1058926
08/21/11 11:40 PM
08/21/11 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the tune up right
Dont ask me ... I dont spray... Monte Smith is the
MAN to talk spraying
Re: Need to go faster [Re: MR_P_BODY] #1058927
08/22/11 12:18 AM
08/22/11 12:18 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes u can do it with a .073 jet in a plate (Wilson I like), and 9 degrees out, with a stock block. I have done it many times. But realize you are running a gerenade with the pin pulled out. It will take that punishment but not alot. It takes alot to set up a proper nitrous system, 2nd fuel system, micro switch, timing retard, c16 feul, not just a 500 dollar kit.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Need to go faster [Re: 1967dartgt] #1058928
08/22/11 12:50 AM
08/22/11 12:50 AM
Peru
Peru
Timming retard is ok, I have a digital MSD.
Second fuel system also ok, but at what pression?
NOS bottle, at what pression?
Micro switch, no problem, but I want it to squeeze on second and thrid gear only. What rear end gears would you recommend?
Also, I run a tunnel ram so I need two plates(what size of jets?)
Thanks for the feed back
Re: Need to go faster [Re: cbarracuda] #1058929
08/22/11 02:33 PM
08/22/11 02:33 PM
owt west
Thread Ender1 Offline
owt west
Carlos, i ran 12 to 1 in my W2 with nitrous so many years ago, dropped the ET WELL over a second. Id run a Single 4 barrel with the unit to simplify things.
Re: Need to go faster [Re: Thread Ender1] #1058930
08/22/11 05:52 PM
08/22/11 05:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What plate are you going to use? nos cheaters, power shots, a speedtech plate , a wilson, single or cross bar set up? All take different jet setups.
Re: Need to go faster [Re: 1967dartgt] #1058931
08/22/11 05:56 PM
08/22/11 05:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
speedtech shower system
Re: Need to go faster [Re: 1967dartgt] #1058932
08/22/11 05:59 PM
08/22/11 05:59 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hey Brad how come 340's can handle it..but 440's blow apart at 600hp after a few passes?
Re: Need to go faster [Re: cbarracuda] #1058933
08/22/11 11:03 PM
08/22/11 11:03 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
factory block an ss springs sounds like you have your work cut out for you, good luck
