Yes u can do it with a .073 jet in a plate (Wilson I like), and 9 degrees out, with a stock block. I have done it many times. But realize you are running a gerenade with the pin pulled out. It will take that punishment but not alot. It takes alot to set up a proper nitrous system, 2nd fuel system, micro switch, timing retard, c16 feul, not just a 500 dollar kit.
hey Brad how come 340's can handle it..but 440's blow apart at 600hp after a few passes?
