Re: Design me a 3G Hemi bracket engine
[Re: MattW]
#1057290
12/07/11 10:43 AM
12/07/11 10:43 AM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
when I talked with the guys with blown up motors and asked them where their timing was set at WOT, most stated their tuners set them between 25 and 26*s. At the dyno with 105 tuning the timing and fuel curves, we heard audible knock at 27* and our DP engine made the most power and tq at 19.5*s thanks to the very efficient chamber design. I'm also a true believer in keeping the knock sensors in the tuning picture. Most tuners take those out of the equation, but I'd rather have the computer pull timing and fuel to save our very expensive engine if it goes into detonation.
I just thought I'd add my 2 cents here.....
- I agree that the knock sensors MUST remain in the equation. I tune quite a few of the GEN III Hemi's and have had many customers with tunes from other shops/tuners where the knock sensors have been desensitized to the point of being of little use.
- I disagree that the WOT timing should be at 19 degrees. Even on bone stock SRT8's, utilizing our loaded Mustang dyno to perform "spark hook" testing we have been able to demonstrate repeatedly that the WOT timing benefits from a carefully tuned curve and depending on the fuel, heads, cam, will be significantly higher than 19 degrees at various points in the WOT RPM/MAP table.
I am also wondering why folks would try to replace the highly efficient EFI system on these engines? I am a carb guy too (Gary Williams dominator), but these systems are hard to beat and are usually included with an engine swap. The 6.1 intake is hard to beat for performance/efficiency up to 7000rpm, there are aftermarket throttle bodies available as well as "stock" higher flowing injectors.
Just my thoughts....
This is a great thread and maybe we can get a Modern Mopar forum set up for these types of discussions?
[Re: 1badx]
#1057291
12/07/11 11:27 AM
12/07/11 11:27 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
For me, primarily it was the fact that the stock 6.1 set-up has absolutley no sex appeal. And with my motor going into old iron (my 70 Road Runner) things must look as cool as they perform......hense the Drag Pack Intake. Long therm plans are go to F.I with the DP Intake, so I didn't want to get into the $1000 conversion wiring harness & stock computor reprogramming blah blah blah....with the stock stuff. So, the simple soution is a carb on the DP Intake.
Re: Design me a late model Hemi bracket engine
[Re: 1badx]
#1057292
12/07/11 11:46 AM
12/07/11 11:46 AM
Posts: 2,826 NY usa
540challenger
NY usa
I have had several requests for engine pricing information on the Gen III Hemi's. I recently have become a distributor for the PWR engines and can email you a price list with options. I would post it here but can't figure out how to attach the price sheet? Email me if you want a copy of the price sheet.
I tune quite a few of the PWR engines and I can tell you that they take the abuse well and are currently setting records across the country.
Good engines for a fair price.
Have you any expereince tunning the Mopar performance progammable ECM I was wondering what it is. IS it just an OBD2 that moapr unlock to be easier to tune or is it just an aftermarket unit like the FAST units.
[Re: STEFF]
#1057293
12/07/11 11:47 AM
12/07/11 11:47 AM
1badx
Portersville, Pa
I guess beauty is in the eye of the beholder Nothing like a dominator sitting on a high rise intake!
But calculate the cost... If you buy a 2005 5.7 swap including the PCM, wire it yourself (not really that complicated, just time consuming) or purchase one of the $750 kits you can buy a used Predator tuning device for $200 and either attempt to tune it yourself or pay me $375. Now you have a grand total of $1500 (or $600 if you wire it yourself) invested in a killer, factory designed system.
Or you can buy a drag pack intake for $900, a good holley carb for $400, some type of distributor system - $$$$$ and then in the future convert to EFI? Custom injector bungs installed in you $900 drag pack intake w/fuel rails - $700 Then you will need and EFI system (ie. Fast, BS3, Holley etc.) close to $2000 + tuning.
I just want to make sure you have all the information and have calculated the total cost. From reading your posts it appears you have thought it out and will build a killer ride!
BTW - if you meant "forced induction" when you said FI, we are making 20+psi on the factory intake, EFI and PCM without issue.
[Re: 540challenger]
#1057294
12/07/11 12:04 PM
12/07/11 12:04 PM
1badx
Portersville, Pa
If you are referring to the AEM unit that Mopar resells, no, I have not. It is a "standalone" unit just like the FastXFI and BS3 units. I personally would carefully consider that choice. I have seen quite a few of these units on the market and have had several Mopar performance parts dealers contact me to see if I wanted to buy a unit that they couldn't sell or use.
AEM makes and EXCELLENT tuning system. The rub is making it work with a Gen III Hemi. The factory PCM is more than sufficient for the most builds.
The factory PCM is OBDII like and requires a CMR dealer for detailed tuning. The handheld Diablosport modules will allow some modifications by the owner but they are limited.
[Re: STEFF]
#1057295
12/07/11 12:14 PM
12/07/11 12:14 PM
1badx
Portersville, Pa
I'm not sure this doesn't have some sex appeal..... It's a customer with a 6.1 swap in a 71 Road Runner
![](http://i229.photobucket.com/albums/ee111/tooslojetta/RR_1.jpg)
[Re: 1badx]
#1057298
12/07/11 12:32 PM
12/07/11 12:32 PM
Posts: 2,826 NY usa
540challenger
NY usa
Thanks for the info. As we speak Iam planning on doing the swap. I already have the alterkation K-frame to make my life easier for the swap. So at least that is done . AS of know my plans seem to be once availble pick up a New 6.4L through mopar either complete or Long block. 6/1L intake. Lock the 6.4L cam "maybe a cam swap at this time" unless by the time i am ready to do this There is a better way to control the VCT. Use a older style computer 2010 and back so it can be tuned.
Do you have an engine dyno to tune or just a chassis dyno. Once I get everything said and done I will would like you to do the work. You seem to have a good handle on the the 3rd Gen. hemi stuff and being located in PA not to far away.
[Re: 1badx]
#1057300
12/07/11 01:08 PM
12/07/11 01:08 PM
Posts: 2,826 NY usa
540challenger
NY usa
Sounds like you've done your homework! We can't tune the 6.4 pcm yet so going with the 2010 or older PCM is a wise choice. Actually, if you can get a 2008 or older PCM to work you will be better off (2009 and up do not have functioning VE tables). ... just a chassis dyno
I actually do quite a bit of email tuning too, so if distance is an issue, as long as you have a wideband or access to a local chassis dyno I can remote tune you.
In your case NY is relatively close and we can get you on our dyno.
And as far as a supercharger I am not partial, Maggie, Kenne Bell, Vortech or Procharger we do them all and the all look sweet! Here's my personal favorite as far as "clean" looking goes a Maggie on a 10 Chally (5.7 vvt) w/spray
Thank for the info on the PCM, I will keep that in mind while hunt down parts. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1badx]
#1057304
12/07/11 02:27 PM
12/07/11 02:27 PM
STEFF
But calculate the cost... If you buy a 6.1 swap including the PCM, wire it yourself (not really that complicated, just time consuming) or purchase one of the $750 kits you can buy a used Predator tuning device for $200 and either attempt to tune it yourself or pay me $375. Now you have a grand total of $1500 (or $600 if you wire it yourself) invested in a killer, factory designed system.
I totally dig what you're saying, but again the factory intake just doesn't do it for me, visually, compared to the DP Intake, and thats a deal breaker. I sold it for $600. Bought the DP Intake for $1000, carb for $300 & for now it works great. I'm using the MSD Hemi 6 controller & will reuse it when I go to Fuel Injection. The DP Intake already has the injector bosses as they run fuel injection.
Yes, it will cost me a few bucks more to go to F.I with the DP intake, but again, the visual appeal is as important to me as the functionality.
Also, I didn't get a factry PCM or factory wiring harness with my motor when purchased. Got a sweet price on the motor though.....$2300
![](http://pic20.picturetrail.com:80/VOL1198/4552955/23827194/397273527.jpg)
![](http://pic20.picturetrail.com:80/VOL1198/4552955/23827194/398170826.jpg)
[Re: 1badx]
#1057305
12/07/11 02:27 PM
12/07/11 02:27 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
http://www.summitracing.com/parts/MSD-6013/MSD $474 And I guess you need a harness for $185 http://www.summitracing.com/parts/MSD-88863/If you are gonna compare used parts then I can use my $50 used eddys instead of new ones. I will have less than $1000 in fuel and ignition and I can keep my little 8psi electric pump, EFI on the other hand you will have to buy a new fuel pump and system desighned for much higher preasure, your wiring will be a nightmare no matter what the experts say, the new hemi has a really thick bundle of wires comeing off it and not all the hemis for sale have the computer or a useable harness still on them, some don't even have intakes or injectors, start piceing that stuff together and watch the price go astronomical on ya ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1badx]
#1057307
12/07/11 02:45 PM
12/07/11 02:45 PM
STEFF
Thanks for the info! I just read the MSD 6013 manual. I did not realize that they had this unit. Are you running it currently and can you give me any feedback on functionality? It looks like it use the same software I use for my MSD Digital 7.
Thanks in advance, Mike
The Hemi 6 Controller works excellent!! It basically uses the same software as the Digital 7 programmable via laptop.
I've run best of 11.05 @ 122mph at 3400lbs. Motor was a stock shortblock, ported heads, PWR cam. I hurt the stock short & blew it up at Monster Mopar, so I have a new motor in the works.
[Re: HotRodDave]
#1057308
12/07/11 02:57 PM
12/07/11 02:57 PM
1badx
Portersville, Pa
HotRodDave - I'm not trying to get in an argument over this. I just want to make sure all the options are out there for each person to review on their own. For you $700 for the ignition and harness, $900 for a drag pack intake and $400 for a carb and $120 for a fuel pump might be best. You are still going to need to install software and setup the ignition/timing but I admit it will be easier/less expensive than paying to have it tuned. So your deal will cost roughly $2100 to implement (unless you buy used or have parts on hand).
I agree that some engines come without intakes, injectors, harnesses and PCM's. If they do, you better be getting them real cheap and accounting for the cost of replacing those items. If not, you are right the costs can be prohibitive. However, if you buy a complete swap with all the above you are still looking at around the same price with retaining the factory pcm. Yes, you do need an EFI fuel pump, we use the Walbro's and they can be found new for $70 shipped.
I will give you that the carb route will be an overall easier install.
However, there are benefits with the factory PCM that will never be realized with the carb setup. (ie. closed loop fuel control - fuel mileage, intake air temp and coolant temp control, cold and hot start features, idle speed control for A/C activation, charging system control, cooling fan control etc.)
As far as the carb look, have you considered the Indy intakes?
