anyone use this Lunati cam ? #1054145
08/16/11 07:20 PM
08/16/11 07:20 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
as i have been looking around to swap out my 509 hydraulic for a solid with a little more power
i have been looking at this cam,has anyone run this ?
Lunati
Part # 60342
Grind # VDBCR-280
lobe seperation 110,106centreline ,251/259@050,566/586 gross lift,014 lash
i am looking for a bit more overall punch with more up top.i would prefer to keep the rpm to 6500 max.
currently shift at 6000 trap 6300
car;440+055,3764lbs,dynamic 9 1/2 5100 flash,4.1 gear 28" hoosier radial
thoughts
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: anyone use this Lunati cam ? [Re: tex013] #1054146
08/16/11 09:17 PM
08/16/11 09:17 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Never used it, but with its lash that cam will have less duration then the 509. With its wider lobe sep it may be a bit soft in the midrange. But with the 5100 stall the two cams may run about exactly the same.
How much ET are you looking to gain?
Re: anyone use this Lunati cam ? [Re: Sport440] #1054147
08/16/11 09:27 PM
08/16/11 09:27 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
i'm only looking to pick up to 11.00.
around 2 tenths
maybe the comp 306S would be better,260/260@050,555 gross lift-022 lash.110 lobe centre,106 intake centreline.3500-6500
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054148
08/16/11 09:35 PM
08/16/11 09:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
around 2 tenths
Tex
Throw the MP 590 in it and give it a go.
Re: anyone use this Lunati cam ? [Re: Sport440] #1054149
08/16/11 09:45 PM
08/16/11 09:45 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
would i need better head flow to run this ? or like the these early grinds they work around their limitations.i have pocket ported stealth heads and 10.78 comp.
how nice are these on the street for daily driving?
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054150
08/16/11 09:53 PM
08/16/11 09:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your head flow at now
Re: anyone use this Lunati cam ? [Re: MR_P_BODY] #1054151
08/16/11 10:02 PM
08/16/11 10:02 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Mr P
i have never had the heads flowed,but they do seem to work
i am open to suggestion.
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054152
08/16/11 10:49 PM
08/16/11 10:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The stealth heads can flow as well as the Eddys. So if yours are pocket ported there probably close to 300 or so. Thats plenty good enough for what you want to do ,IMO.
And Yes , your current combo works darn great.
My Old 509 combo was at 10.78 comp too, and ran 10.47,s @ 3000# It would of been faster with a 5100 vert vs a 4100 vert. 10.30,s or so I bet.
Re: anyone use this Lunati cam ? [Re: tex013] #1054153
08/16/11 11:05 PM
08/16/11 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mr P
Tex
I think that cam your looking at would be about perfect...
yes it will have a little less duration at the tight
lash but the wider LSA will help the top end and it
wont be soft in the mid range...street driving the
wider LSA is nice but it wont have much lope to it
if you like that
Re: anyone use this Lunati cam ? [Re: MR_P_BODY] #1054154
08/16/11 11:31 PM
08/16/11 11:31 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys,
now to save for all the little extras and check P toV clearance.
as to idle lope not a worry if it makes plenty of power.the 509 idles around 800rpm in gear now
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: MR_P_BODY] #1054155
08/17/11 12:50 AM
08/17/11 12:50 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mr P
Tex
if you like that
If he wants to gain 2 tenths that cam will be far from perfect IMO. In a similer test I lost a tenth from a such a change. But with the 110 LS it was much more street friendly. But similer doesnt mean exact.
It was a HD vs HD, but the approximate lifts and duration "differences" would of been about the same between the above mentioned 248* 509 HD and the 251* Lunati solid.
My two cams numbers were
1st cam:
108 LS MP 484
.484 lift 241*@.050 Intake.
.484 lift 241*@.050 Exhaust.
2nd cam:
110 LS Eddy 480
.480 lift 238*@.050 Intake.
.495 lift 246*@.050 Exhaust
On the above test I was expecting A bit more ET and top end with the combo. A little more low end grunt with the shorter intake duration and a little more top end with the wider LS and more exhaust duration.
The results were about 1 to 1.5 tenths less with a more streetable driving combo. Both cams were installed 4* advanced.
The conclusion I gained from this was, between all the differences between the two cams at LS,intake Lift/exhaust Lift.
At this level of duration, Duration @ .050 played the biggest part in performance.
Not lobe sep., or higher exhaust lift.
Re: anyone use this Lunati cam ? [Re: Sport440] #1054156
08/17/11 01:09 AM
08/17/11 01:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mr P
Tex
if you like that
1st cam:
108 LS MP 484
2nd cam:
110 LS Eddy 480
This is a solid(not a hyd)... it will pull more
RPM than the hyd... thats why I asked the head flow
which you believe can do it
Re: anyone use this Lunati cam ? [Re: MR_P_BODY] #1054157
08/17/11 03:01 AM
08/17/11 03:01 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Mr P,Sport440
i ran a couple of cams through Cam Quest to get some ideas.
guesstimates using my inputs
the Comp 509 nostalgia : 556hp/531flb
Comp XS290S(similar to Lunati)252/260@050 : 588hp/552flb
Comp 306S, 260/260@050: 588hp/532flb
Comp XTQ286S, 256/266@050 : 588hp/547flb
these peak hp numbers look about 25hp up but like a dyno just gives comparisons
All show near identical HP and similar tq.I am giving up around 30HP and some tq
Peak power is estimated at 6500,tq at either 4500 or 5000.keeps it all around my self imposed max rpm.but may push into the 10's,i guess short shifting will help there if necassarry
i guess its pluck a number from the hat
thanks again,
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054158
08/17/11 07:18 AM
08/17/11 07:18 AM
gregsdart Online content
gregsdart  Online Content
A basic 440 package responds to more cam duration and likes 108 or less lsa. these are torque motors, narrow lsa cams are torque cams. Put a cam in it with some serious duration and you will be rewarded with a serious hp improvement. Put a similar cam in it or something with a little more duration, and you MAY get a little more hp. You have the stall to run the 590. Put it in at 102, check V p, and fix. Then go run the number you want. Simple. And you can shift at 6200.
Basically you need head flow equivalent to Eddys, or well ported Iron heads. An 850 cfm carb, single plane manifold and 2 inch headers with long collectors.
I know of two guys both running this combo, one at 3700 lbs, one at 3800 lbs. Both have run tens.
Re: anyone use this Lunati cam ? [Re: gregsdart] #1054159
08/17/11 01:45 PM
08/17/11 01:45 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You have just described my package Greg, mine has 4800 stall, 4.56 gear, 12.5.1 comp, 950 holley, 2" TTI's with collector extensions at 3200# and i think there's a 10.1 in my car with more tuning, shift at 6200 goes through the line at 6500.
I cant believe how good this cam is.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: anyone use this Lunati cam ? [Re: deaks] #1054160
08/17/11 09:35 PM
08/17/11 09:35 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Although your OP was about a solid cam, this is an option to keep your hydraulic setup and gain a bit more punch in the swap.
StreetWize has commented that the Lunati 30307 cam is a much better performer than the Mopar 509 you currently run.
240/250 @ .050 .520 int /.547 exh
http://www.summitracing.com/parts/LUN-30307/
http://www.lunatipower.com/Product.aspx?id=1568
You might PM StreetWize and ask him about his results/opinion.
Here are a couple pertinent links to read on the topic:
https://board.moparts.org/ubbthreads/show...rue#Post6010517
https://board.moparts.org/ubbthreads/show...rue#Post4911436
Regarding a great running Solid cam, a call to Tim Goolsby @ UltraDyne/Bullet would be great idea.
Re: anyone use this Lunati cam ? [Re: topbrent] #1054161
08/17/11 11:35 PM
08/17/11 11:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Lunati cams are Great! 451 Jim uses this 30307 cam on his 3800# street car and it runs 11.70 or better something, If I remember correctly.
But with the 5100, Vert in the OP,s combo. Its to short on duration, to walk the dog on the old MP 509.
Tex, needs more then just a "Similer" Cam Tweak to gain .2 tenths in the 1/4 with his 3700# ride
Re: anyone use this Lunati cam ? [Re: Sport440] #1054162
08/18/11 12:36 AM
08/18/11 12:36 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks again for all the input.
the 590 looks unobtainium at the moment,no biggy as i'm not ready yet.
Deaks,i know you have more comp but how does your motor/590 cam idle - way high?rough like a 509?
am i correct in thinking that i will need 6 - 8 degrees more duration on a solid to be somewhat equivilent to a hydro cam.hence from what some are saying i may really need closer to 260 or 265 to see a real gain,plus raise my peak power to around 6300 from 5800 now.is this what you are pointing out Greg ?
by the way i have 1 7/8 hooker comps into a 3"system to the diff with aero chambers.825 mighty demon on a M1 single plane.
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054163
08/18/11 01:29 AM
08/18/11 01:29 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Tex
Engle Cams has a similar cam to the MP .590.
Part # 2387 .600" lift 274* duration @ .050 106lca
Install it at 102 and it should get you in the 10's easy.
Re: anyone use this Lunati cam ? [Re: moparmanjames] #1054164
08/18/11 02:06 AM
08/18/11 02:06 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I use a Lunati #40316 in one of my 440s and it specs very close to what is being recommended here...
Adv. Duration:322/322
Duration @ 0.050" :276/276
Gross Valve Lift:.600"/.600"
Lobe Separation Angle / Intake Centerline:108/106
http://www.race-mart.com/Lunati-LTI-40316.html
