Wrong oil filter? UPDATE!! #1051486
08/12/11 12:43 PM
08/12/11 12:43 PM
Home of the Dream Cruise
FPD031 Offline OP
FPD031  Offline OP
The motor was just rebuilt and when I started it for the 1st time I had to really crank on the oil filter to get it to stop leaking. After changing the oil and filter, the new filter is still leaking after tightening it with the filter wrench. I checked where the filter screws onto and I don't see any nicks or gouges. What else am I missing? It is comming from the top of the oil filter.
Wix # 51515, this is what the parts guy gave me.
The plate that RR supplied me appeared to cure the problem. I swapped the one he sent me with mine and no more leaks. I looked at mine and could see no obvious difference between the 2. I even reused the filter and the old plate gasket. Go figure. Robert my cleaned up oil soaked floor thanks you very much. You be my new bestest buddy,
Stay tuned for parts identification quiz comming, Stuff I never tagged when I took it off 4 years ago thinking it would remember where it went. Yeah right!
Re: Wrong oil filter? [Re: FPD031] #1051487
08/12/11 12:53 PM
08/12/11 12:53 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
What engine are you talking about ? If it is a smallblock, does it have the angled adapter, or straight ? You may have adapter gasket problems with either one .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Wrong oil filter? [Re: FPD031] #1051488
08/12/11 01:00 PM
08/12/11 01:00 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Shouldn't need to tighten any more than hand tight. Something is wrong. There isn't an old gasket stuck to the filter mount?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Wrong oil filter? [Re: FPD031] #1051489
08/12/11 01:55 PM
08/12/11 01:55 PM
SB I'm assuming. Need to pull the nipple/plate & Felpro sells the large circular gasket seperate as opposed to the MP 3 piece blister pack & the FP one is slightly thicker/seals better. clean the block circular recess thoroughly & your plate may b warped but start w a good visual & go from there & I have one if you end up needing one
Re: Wrong oil filter? [Re: HemiRick] #1051490
08/12/11 01:55 PM
08/12/11 01:55 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
CHECK to see if there is an o-ring on the filter. I have heard of them missing. ALSO ..I had a Pennzoil filter that had a very shallow o-ring in it that needed to be super-tight.
x2 ...all they need is a medium hand-tight.
Re: Wrong oil filter? [Re: dOOc] #1051491
08/12/11 04:44 PM
08/12/11 04:44 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
O ring or rubber seal? When you say o ring I am thinking small seal. Seal would be larger. Does wix have 2 seals?
Re: Wrong oil filter? [Re: MI_Custumz] #1051492
08/12/11 05:21 PM
08/12/11 05:21 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
It is a square O-ring that is near the outside edge of the filter. I have only seen a single seal/o-ring on any spin-on filter.
Re: Wrong oil filter? [Re: FPD031] #1051493
08/13/11 01:37 AM
08/13/11 01:37 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
RapidRobert is right.
The seal under the filter mount plate may be bad. Take the plate off & replace the seal. When it leaks it looks like filter is leaking.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Wrong oil filter? [Re: RapidRobert] #1051494
08/13/11 09:08 AM
08/13/11 09:08 AM
FPD031 Offline OP
FPD031  Offline OP
It is a 318. After the initial start up, I pulled the nipple off, but the plate wouldn't budge from the motor. I didn't know if it was suppose to come off so I didn't force it. Also, there was no gasket between the nipple and the plate. Is there suppose to be? I'll pull the filter and check again.
Re: Wrong oil filter? [Re: FPD031] #1051495
08/13/11 10:27 AM
08/13/11 10:27 AM
Yes it comes off & gently pry it w a screwdriver in the center at diff points around the perimeter which may bend it & it may already b bent but you have no choice. Correct, there is no gasket on the nipple. Send me your address & I'll get a plate out to you Monday if that'll work 4 you
Re: Wrong oil filter? [Re: RapidRobert] #1051496
08/13/11 11:32 AM
08/13/11 11:32 AM
FPD031 Offline OP
FPD031  Offline OP
It won't let me send you a PM Robert. Anyway, thanks for the assist. I'll take the plate and give that a try. I've got this filter on so tight, I'm hoping I can get it back off. Let me know on the cost with shipping.
Thanks,
Dave Watters
1072 W. Curtis Rd
Saginaw, MI 48601
Re: Wrong oil filter? [Re: FPD031] #1051497
08/13/11 11:36 AM
08/13/11 11:36 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Don't be surprised if some parts stores have no clue of how to find the gaskets, even the large outer one. Some places around here don't show a listing.
Re: Wrong oil filter? [Re: buildanother] #1051498
08/13/11 11:40 AM
08/13/11 11:40 AM
FPD031 Offline OP
FPD031  Offline OP
I thought about that. Another worry. I cross that bridge when I get the plate out and can take the plate and gasket up there so they can see exactly what I'm talking about.
Re: Wrong oil filter? [Re: FPD031] #1051499
08/13/11 12:01 PM
08/13/11 12:01 PM
Dave I'll grab the plate today/package it/send it out Monday. Just checked & yes my PM's are full/need to go thru them. When I reach 283 it gets (red) flagged, must b a chebby thing. The Felpro # is 70522 for the large circular single gasket
Re: Wrong oil filter? [Re: RapidRobert] #1051500
08/13/11 01:00 PM
08/13/11 01:00 PM
FPD031 Offline OP
FPD031  Offline OP
Thanks for the number. That will make things alot easier.
Re: Wrong oil filter? [Re: FPD031] #1051501
08/13/11 02:58 PM
08/13/11 02:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Even though many people praise WIX filters, a few years back they had a bad run where the screw-on threads were tapped wrong..
The filter would start but not thread on very easily/smoothly, I knew something was wrong so I ended up not using these as I didn't want to screw up the fitting on the oil pump. I did talk to the guys @ WIX and they tried giving me the sunshine treatment...
So I chucked the filters and switched brand. The next time I was @ Napa they confirmed that they had sent back many filters to WIX as they had a bad run..
Just my $0.02...
