Difference in A body wiring harness
#1050732
08/10/11 08:12 PM
08/10/11 08:12 PM
Posts: 564 Round Rock,Tx
Nirvana
Round Rock,Tx
Im thinking about ordering a new engine wiring harness for the 69 Dart. Does anyonw know if one from a 70-72 Dart/Duster/Demon would work? I was going to upgrade to the 70+ electronic voltage regulator,so im trying to see if I can use a harness that already has it.
87 D100 225 4 speed.
Re: Difference in A body wiring harness
[Re: Nirvana]
#1050733
08/10/11 08:15 PM
08/10/11 08:15 PM
Posts: 5,337 the house on the left.
cogen80
if you order from year one they have 69 harnesses that are wired so ecectronic ign and a dual fld charging system is plug and play.
[Re: Nirvana]
#1050738
08/11/11 07:40 AM
08/11/11 07:40 AM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
I was thinking about going with Evans,or trying to find one used in good shape.
stay away from evans garbage. i used one a few years ago and it had bad crimps all over the place on it. there is a thread floating around this site where quite a few guys had the same issues with poor fitting and bad crimps.
go with the year one (M&H) harness. its a quality piece, and actually fits. plus its real close to the same price as the evans. like cogen said, you can ger a 69 harness that is set up for the newer style regulator and alt along with electronic ign. just installed a harness from year one in a friends 68 dart. dropped right in, very nice piece.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: Kern Dog]
#1050739
08/11/11 07:43 AM
08/11/11 07:43 AM
abodyjoe
Berlin, N.J.
Are you ready to spend $600 on a wiring harness? For half that kind of cash, you should certainly be able to have someone sort out what you have.
for just an engine harness?
$185 from year one. the same harness is $110 from evans. spend the extra money and just be done with it.
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
HU201AM Reproduction engine and forward light harness modified for electronic ignition for 1969 Dart models with 318 or 340 engines and all V8 Valiant models.
eproduction harness requires the use of the 1970-and-later style alternator and electronic voltage regulator. If using an aftermarket electronic ignition system, our manufacturer suggests that a reproduction harness for point ignition would be a better starting point. Use this harness for plug & play termination of a Chrysler electronic ignition system.
[Re: Nirvana]
#1050741
08/11/11 08:59 AM
08/11/11 08:59 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
To answer this question , NO you can't just buy the later harness and use it on your 69.
But as said you can buy a harness that has the Electronic incorporated into it and you can also get the 2 field charging system ...assuming M+H does that style also .
[Re: JohnRR]
#1050742
08/11/11 09:20 AM
08/11/11 09:20 AM
Posts: 15,487 Florida
scratchnfotraction
I patched up the 68 dart /6 harness i had when I swaped to SB.
I just used the upgrade voltage reg for the 1 feild wire alt,then used a pertronix points conversion with the pertronix flame thrower coil,by-passed the BR for a full 12 volts to the coil.
even had the 68 alt it came with,no more dim lights/discharge at low idle.
i did upgrade the batt wire and wire from relay to starter to 1 gauge cable,that spun the stock /6 starter on the SB pretty good after that.
I vote fix what you got ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#1050743
08/11/11 09:22 AM
08/11/11 09:22 AM
JohnRR
That's nice but it doesn't really answer the question he asked ... but this is Moparts and this is par for the course ... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: JohnRR]
#1050744
08/11/11 09:28 AM
08/11/11 09:28 AM
scratchnfotraction
my bad..was just a suggestion ![](/ubbthreads/images/graemlins/45.gif) you had already said it was a no go on the harness and the other harness is $$
[Re: JohnRR]
#1050745
08/11/11 09:30 AM
08/11/11 09:30 AM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here is a little bit of info for you, the slant six and big block harness have the same part number... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I try and use the original and repair it instead of going with new wiring unless it is totally trashed, can't beat the factory stuff! ![](/ubbthreads/images/graemlins/Twocents.gif) As said above, every year changed enough that it is hard to swith between years unless you know your stuff!
JB Rhinehart, Realist
A-Body's RULE!
[Re: JohnRR]
#1050746
08/11/11 10:38 AM
08/11/11 10:38 AM
cogen80
yes they do.. the part number is posted above HU201AM
#1050747
08/11/11 12:09 PM
08/11/11 12:09 PM
JohnRR
I was just funning you .
I have gone the same way as you in the past ... Pertronics , but the new stuff is made in china and I have seen enough people have a negative experience with them now that it's no longer a viable alternative to me , the 2 setups I have are many years old and made in the good ole USofA , but that doesn't stop me from having a points distributor, coil and ballast handy on a long trip just in case .
[Re: Nirvana]
#1050749
08/13/11 04:50 AM
08/13/11 04:50 AM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
Ever consider just runnng new wires? I bought all new connections for the engine side of the bulkhead. Ran each wire 1 at a time. There really isnt that much to it. Did the MAD conversion, batt relocation, denso alt, headlight relays, MSD under the dash, blah blah blah. Point is, it's all quite simple(I'm no pro, believe me) make good connections and solder everything. AND it was fun and way cheaper. Just another option to consider ![](/ubbthreads/images/graemlins/beer.gif)
