Difference in A body wiring harness #1050732
08/10/11 08:12 PM
08/10/11 08:12 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Im thinking about ordering a new engine wiring harness for the 69 Dart. Does anyonw know if one from a 70-72 Dart/Duster/Demon would work? I was going to upgrade to the 70+ electronic voltage regulator,so im trying to see if I can use a harness that already has it.
87 D100 225 4 speed.
Re: Difference in A body wiring harness [Re: Nirvana] #1050733
08/10/11 08:15 PM
08/10/11 08:15 PM
the house on the left.
cogen80 Offline
cogen80  Offline
if you order from year one they have 69 harnesses that are wired so ecectronic ign and a dual fld charging system is plug and play.
Re: Difference in A body wiring harness [Re: cogen80] #1050734
08/10/11 08:46 PM
08/10/11 08:46 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
I was thinking about going with Evans,or trying to find one used in good shape.
Re: Difference in A body wiring harness [Re: Nirvana] #1050735
08/10/11 11:05 PM
08/10/11 11:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd use M&H harnesses, they are only sold through Year One.
M&H has an extensive list of correct Mopar harnesses, if you don't see what you are after in the YO catalogue you can call them and they will contact M&H to get you the right one. M&H is ISO 9000 approved and uses pull testing, etc. to ensure good quality control. They also have most of the Chrysler blueprints so you know it will be right to factory specs.
MANY things changed between 69-71, I would not attempt a swap like that unless you REALLY know your stuff because you'll need to make plenty of mods.
Do yourself a favor and go with YO, it's expensive but WELL worth it IMO
Re: Difference in A body wiring harness [Re: ScottSmith_Harms] #1050736
08/11/11 01:10 AM
08/11/11 01:10 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Are you ready to spend $600 on a wiring harness? For half that kind of cash, you should certainly be able to have someone sort out what you have.
Re: Difference in A body wiring harness [Re: Kern Dog] #1050737
08/11/11 04:12 AM
08/11/11 04:12 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
No, thats why I was looking at evans wiring for 95 bux. Its only the engine harness that needs to be replaced/repaired.600 is more than I paid for the whole car,and I can do the wiring repair myself. I was just thinking it would be easier to replace the entire harness,and start over with a clean slate. I've been doing some research, and am getting mixed reviews on both the evans, and year one harnesses. Some say both are great,some say evans don't crimp properly,and some say year one takes over two months to get.Hmmm might just fix what I have and call it good.
Re: Difference in A body wiring harness [Re: Nirvana] #1050738
08/11/11 07:40 AM
08/11/11 07:40 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
stay away from evans garbage. i used one a few years ago and it had bad crimps all over the place on it. there is a thread floating around this site where quite a few guys had the same issues with poor fitting and bad crimps.
go with the year one (M&H) harness. its a quality piece, and actually fits. plus its real close to the same price as the evans. like cogen said, you can ger a 69 harness that is set up for the newer style regulator and alt along with electronic ign. just installed a harness from year one in a friends 68 dart. dropped right in, very nice piece.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Difference in A body wiring harness [Re: Kern Dog] #1050739
08/11/11 07:43 AM
08/11/11 07:43 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
for just an engine harness?
$185 from year one. the same harness is $110 from evans. spend the extra money and just be done with it.
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
HU201AM Reproduction engine and forward light harness modified for electronic ignition for 1969 Dart models with 318 or 340 engines and all V8 Valiant models.
eproduction harness requires the use of the 1970-and-later style alternator and electronic voltage regulator. If using an aftermarket electronic ignition system, our manufacturer suggests that a reproduction harness for point ignition would be a better starting point. Use this harness for plug & play termination of a Chrysler electronic ignition system.
Re: Difference in A body wiring harness [Re: abodyjoe] #1050740
08/11/11 07:55 AM
08/11/11 07:55 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
Re: Difference in A body wiring harness [Re: Nirvana] #1050741
08/11/11 08:59 AM
08/11/11 08:59 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
To answer this question , NO you can't just buy the later harness and use it on your 69.
But as said you can buy a harness that has the Electronic incorporated into it and you can also get the 2 field charging system ...assuming M+H does that style also .
Re: Difference in A body wiring harness [Re: JohnRR] #1050742
08/11/11 09:20 AM
08/11/11 09:20 AM
scratchnfotraction Offline
I patched up the 68 dart /6 harness i had when I swaped to SB.
I just used the upgrade voltage reg for the 1 feild wire alt,then used a pertronix points conversion with the pertronix flame thrower coil,by-passed the BR for a full 12 volts to the coil.
even had the 68 alt it came with,no more dim lights/discharge at low idle.
i did upgrade the batt wire and wire from relay to starter to 1 gauge cable,that spun the stock /6 starter on the SB pretty good after that.
I vote fix what you got
Re: Difference in A body wiring harness [Re: scratchnfotraction] #1050743
08/11/11 09:22 AM
08/11/11 09:22 AM
JohnRR Offline
JohnRR  Offline
That's nice but it doesn't really answer the question he asked ... but this is Moparts and this is par for the course ...
Re: Difference in A body wiring harness [Re: JohnRR] #1050744
08/11/11 09:28 AM
08/11/11 09:28 AM
my bad..was just a suggestion
you had already said it was a no go on the harness and the other harness is $$
Re: Difference in A body wiring harness [Re: JohnRR] #1050745
08/11/11 09:30 AM
08/11/11 09:30 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Here is a little bit of info for you, the slant six and big block harness have the same part number... I try and use the original and repair it instead of going with new wiring unless it is totally trashed, can't beat the factory stuff! As said above, every year changed enough that it is hard to swith between years unless you know your stuff!
JB Rhinehart, Realist
A-Body's RULE!
Re: Difference in A body wiring harness [Re: JohnRR] #1050746
08/11/11 10:38 AM
08/11/11 10:38 AM
cogen80 Offline
cogen80  Offline
yes they do.. the part number is posted above HU201AM
Re: Difference in A body wiring harness [Re: scratchnfotraction] #1050747
08/11/11 12:09 PM
08/11/11 12:09 PM
JohnRR Offline
JohnRR  Offline
I was just funning you .
I have gone the same way as you in the past ... Pertronics , but the new stuff is made in china and I have seen enough people have a negative experience with them now that it's no longer a viable alternative to me , the 2 setups I have are many years old and made in the good ole USofA , but that doesn't stop me from having a points distributor, coil and ballast handy on a long trip just in case .
Re: Difference in A body wiring harness [Re: abodyjoe] #1050748
08/11/11 02:41 PM
08/11/11 02:41 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Joe-
Evans quoted me 130 for the points style harness,because I have a slant six,and the wires are longer So if I go new,it would be the YO harness.
Thanks to everyone for the ideas,for now I am going to stick with the stock wiring and just fix it. Its really not that bad,and I have the plug/connector so I can wire in the electronic voltage reg.
Re: Difference in A body wiring harness [Re: Nirvana] #1050749
08/13/11 04:50 AM
08/13/11 04:50 AM
Medford OR
FrankenScamp Offline
Medford OR
Ever consider just runnng new wires? I bought all new connections for the engine side of the bulkhead. Ran each wire 1 at a time. There really isnt that much to it. Did the MAD conversion, batt relocation, denso alt, headlight relays, MSD under the dash, blah blah blah.
Point is, it's all quite simple(I'm no pro, believe me) make good connections and solder everything. AND it was fun and way cheaper.
Just another option to consider
